Question about Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers
Logitech X-530 speaker set plugged in as per instructions delivering sound from only front speakers and sub woofer. Nothing from centre and rears. XP system with ASRock ALiveDual-eSATA2 mother board. (supports up to 8 audio channels). 5.1 surround sound selected in Control Panel. (Though defaults after switch off to Stereo Desktop speakers) Any ideas please on how to get sound from all speakers?
  • Logitech Master
  • 10,291 Answers
Make sure the cables are plugged in the correct places on your PC. You may need to use the headphone out on the back panel. This depends on your audio card in your PC.
Posted on Aug 09, 2017
  • 38 Answers
SOURCE: Sub Woofer Stopped working
May be when you turned it, some of the wire connection inside must have got broken or the magnets must have got displaced or somewhere connection would have got loosen check all of this.
Posted on Jul 17, 2008
SOURCE: Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Posted on Sep 24, 2008
  • 89 Answers
SOURCE: hook up z-5500 suround to a tv
The Sony has (http://b2b.sony.com/Solutions/product/KDL-46S4100)
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=GB,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Posted on Oct 28, 2008
SOURCE: Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Posted on Feb 01, 2009
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
Aug 06, 2010 | Logitech X-530 Computer Speakers
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
Can find driver for logitech 5.1 x-530 speekers
eBay you might type in major brand on eBay you can get a 5.25 Polk woofer for super cheap may not be logitech but iv done it and to me it sounded good. about to buy a logitech x 530 speaker set for my z 640 surround its compatible if you want the sub woofer than email me if not you can eBay your system and get a busted one to pull pars from.
Mar 12, 2010 | Logitech Audio Players & Recorders
X-530 logitech surround speakers how do I install please
coming from the speaker with volume control, there is a cable with 3 jacks, connect them while your computer is running, yellow to pink, green to green, black to blue. a window should open asking what you connected. green is front, yellow is center/sub, black is rear
Dec 27, 2009 | Logitech X-530 Computer Speakers
Only the front left and right + sub woofer work. the front center and two rear speakers do not work. when i set the options to speaker fill all the speakers work but the bass suddenly goes very weak. why?
This is your surround sound system they should work when you are watching a movie with surround sound. make sure that you polarity are correct on all speakers.
Nov 28, 2009 | Logitech X-530 Computer Speakers
When connecting the leads to the sound card do i plug one into the pc. and should all the speakers work straight away,I only have thee woofer and the centre speaker working.. LOGITECH X-530
There are leads that need to be connected to your computer for the Front, Rear, and Subwoofer speakers Not all motherboards have all of these connections Your Logitech manual shows how to connect the speakers correctly if you do not have all of the connections on your motherboard
Sep 14, 2009 | Logitech X-530 Computer Speakers
Woofer and two front speakers work, nothing else.
Did you configure your computer to use theother speakers. Go to control Panel and then Sound and you should be able to configure it there. it also depends on what type of sound card your computer has.
Jun 13, 2009 | Logitech X-530 Computer Speakers
I just bought new speakers (logitech x-530) which is 5.1. sound only comes out of the front 2 speakers and the sub but not the back 2 and the centre. any ideas? computer specs are: motherboard - asus...
Sorry just doublechecked your board specs. Go to the sound properties in control panel. Click on the configure speakers option. If everything is plugged in right then windows should configure it for you to a 5.1 config. Hope this helps.
Dec 27, 2008 | Logitech X-530 5.1 Channel Speaker System...
Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Sep 22, 2007 | Logitech X-530 Computer Speakers
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
