Question about Jura Capresso Jura / Capresso IMPRESSA J5 Espresso Machine
The Impressa J5 keeps asking me to empty grounds even though the grounds tray is empty
2 Suggested Answers
  • 4 Answers
SOURCE: impressa z5 grounds empty will not reset even
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
My jura j9 continues to show the error of "empty drip tray" I have cleaned the metal connectors in the back and cleaned and dried the back of the Machine. Please help
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really dirty!.
Nov 25, 2015 | Capresso Jura Impressa J9 One Touch...
How do I fix tray empty message on Jura capresso z6?
RB5193 wrote: If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch.
finally found it - look inside the large opening where the entire tray part fits - all the way up front - just inside the opening, not in the back where the contacts fit, but way in front - there resides the white micro switch - loosen it up and voila! It works (after 4 hours of hunting, scraping, filing etc - it works like a charm - photo attached, I hope. Thank you RB5193!
Jul 03, 2015 | Jura Capresso Impressa Z5 Espresso/Coffee...
Cannot install tray with ground basket installed, after removing. Mechanism is blocking the ground basket when the tray is slid back into the unit after emptying.
Try putting a container under the coffee spouts and pressing the rinse button. This will usually free any coffee grounds that may not have been expelled into the grounds basket from the last time the machine was used. The grounds can get stuck and block the slide path of the grounds basket.
Dec 23, 2010 | Jura Capresso Jura / Capresso IMPRESSA J5...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
The tray (JURA J5) keeps indicating that it needs to be emptied inspite of it being empty. How can i fix this problemo? Thank you.
The connectors at the back have liquid on them use a lint free cloth to remove the liquid and the tray fault will go away. If you want to prevent this make sure that when you pour the water out the tray you pour it out the side not the back and this is how the liquid or debris gets stuck there
Oct 31, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Impressa z5 grounds empty will not reset even though the tray has been empty and the contacts cleaned
Oct 13, 2009 | Jura Capresso Impressa S9 Coffee...
Impressa E8: even though I did clean machine, it asks me again...
Make sure your water tank to fill, when you start the clean process, and the tray is empty and wiped down. Then add a 500ml container under the spout rather than let the water go into the tray.
Also if you have not serviced the machine for about 5,000 cups this can occur.
Mar 23, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Tray empty message
Nov 15, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Jura / Capresso IMPRESSA J5 Espresso Machine Logo
328 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
