Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Machine not spinning or draining water - Hotpoint Aquarius WD640 Front Load Washer/Dryer
    Problem Solver:
  • 10 Answers
Machine has to pump out before it can spin.So if not pumping out it is either blocked up somewhere or the pump is jammed.If pump is on the r/h/s behind the plastic plinth try to undo filter (obviously having bailed the machine out as much as you can before hand otherwise you`ll get a triffle moist!) undo filter and clean it out and dry around so that when you refit the filter it will not leak+get a torch and look into the pump chamber you should see a white four bladed impellor-have a damn good look and see if there is anything jamming this impellor,if so remove it carefully without breaking the impellor.See if this is the problem and or before you do this ,if your outlet pipe pushes to the nozzle under the sink rather than down a down pipe,check here for blockages too as very common on the washer dryers.
Posted on Dec 29, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
My machine is barely draining water on the drain and spin cycle. It will spin but does not empty all the water out of the machine.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Water drain open even washing mode and during spin water not drain
heatman101
Aug 29, 2010 | LG Washing Machines
LG Washing Machine won't spin, signals that load isn't balanced
Check the drain clean out at the drain pump. If is cloggedm with debris, it will not spin and go off a a long drain error code.
Feb 06, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
My washing machine got to the spin cycle but didn't drain water
prolly cuz you didnt check your pockets first and either change or a set of keys fell out
Aug 15, 2009 | Washing Machines
The drain/spin cycle always adds water
It's normal if it just adds a little bit of water. It does this so your drain pump impeller doesn't run dry which could damage it. If it's filling right up, there could be a malfunction with the control board, the pressure switch or the inlet valve .
You could try shutting off the water supply at the taps before you start the drain/spin cycle.
Feb 08, 2009 | Whirlpool GHW9400 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
57 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
