Question about Compaq Evo N610C Notebook
SHUTTING DOWN I press the power button and the laptop starts to whine...then immediately shuts down...it does this with battery and power cord.....
  • melball Jul 21, 2008
    It is the hard drive whining....so if I replace the harddrive will the computer come on?
    Genius:
  • 2,028 Answers
Whining usually comes from the hard drive and indicates that it's beginning to fail. Locate the hard drive in your machine, hit the power button, then listen to see if the sound is coming from the hard drive area, if so, then the hard drive is beginning to fail. As far as it failing, it may go the next time you turn it on or it my last for months, hard drives a funny that way.
Posted on Jul 07, 2008
  • Ryan Rogers
    Ryan Rogers Jul 22, 2008
    You will have to reformat the new hard drive using NTFS and reinstall the operating system. After the install you will need to download a few drivers from Compaq's support site and a few Windows updates. Then yourr machine will work just fine. If you have anymore questions, please ask.
I have a Proline W763S laptop and it won't start
Whats plugged into laptop ? Try unplugging any USB and any external VGA cables. Try holding down power button for 30 seconds and then try again. Also Try power button being held down for 30 seconds to shut down laptop and then remove power cord and battery and then reinsert them into laptop.
Sep 08, 2014 | Computers & Internet
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Windows 7 wont shut down
What happens when you try to shut it down? You can always try Pressing and Holding the Power Button until it shuts down.
If it is stalling when you go thru the normal shut down process then just wait a few minutes then press and hold the power button.
If pressing and holding the power button don't work, remove the power cord, then remove the battery. This will surely work because there will be no power source.
May 06, 2012 | Computers & Internet
I cannot turn off the computer
Chances are, there's a program running in the background that won't let it shut down. Try closing all your programs and shutting it down. If that doesn't work, you can hold the power button down until it shuts down, or possibly remove the battery. If this problem continues occuring, try running a virus sweep and seeing if it catches anything on your system. For a good free online virus sweep, use: http://housecall.trendmicro.com/
Hope this helps!
Mar 28, 2011 | ASUS Eee 4G Notebook
After charging battery, when I press start, it attempts to start and then immediately shuts down. After recharging the battery a while, and attempting restart, the same thing happens again.
Hi
Have you tried to use your computer when power charger is connected to power supply? Then try it to check if your computer does not shut down. If do not shut down it self. You had problem with the battery or with charger not compatible with the battery. Normal problem of shutting down computer is that your battery have no charge, your battery is not compatible with your laptop or ever defective. Tr
Jan 10, 2011 | Averatec 3200 Notebook
I attempted to shut the computer down via the startup menu but closed the laptop prior to it shutting down. When I reopened and turned on it asked for password to log into windows but the hour glass...
Try pressing and holding the power button until the computer shuts down.
Also note that when removing the battery, you also need to unplug the power cord in order to shut down the computer in that manner.
Dec 29, 2010 | Computers & Internet
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
M-series gateway (m1629) press start button, nothing
Taken apart, looking for abnormal solder etc checked powers switches decided that this unit was acting like it may have shut down due to excessive heat issue. pulled battery on board, tested ok, re-installed everything and found that this unit now is active. Conclusion: I suspect the bios shut this unit down, hard reset correct this issue.
Aug 24, 2009 | Gateway Computers & Internet
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Doesnt stay on
sounds to me like power cord failure.  it is running off battery power and with no power cord it cant recharge and shuts down to save data
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Compaq Evo N610C Notebook Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
