Question about SYMA Toys industrial Toys
Problems with s026g 3.5 channel gyro chinook - does not respond straight away when using remote even though followed the instructions fully
  • 399 Answers
SOURCE: TV stopped responding to remote control
shut off the tv directly from the main power outlet.remove the plug from the outlet.also change the remote batteries.and reinsert the wire after 10 minutes.and check it will work as normal.
thanks.
Posted on Oct 12, 2008
JSEhandyman
  • 368 Answers
SOURCE: Red light far right blinking continuosly (#26)
Hi jason,
The flashing red light indicates tha _something_ is not positioned correctly. Please check and see if you can find the sensor(s) that determine whether or not the components are correctly positioned.
You might also try unplugging it for 10-20 minutes to allow any electronic sensors to reset when you reconnect power.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 02, 2009
  • 20 Answers
SOURCE: have admiral tv with rca systemlink 3 remote.
http://www.parkwon.com/rcatest/
go here
Posted on Apr 14, 2009
lostinfamily
  • 149 Answers
SOURCE: Nunchuck is not working even though connected to wii remote
The sensor may be gone.  The best way to test this is really easy and pretty cool to do.  Take two candles light them and then place them a little further apart than the wii sensor is.  If you are able to use the remotes then the sensor bar needs to be replaced and if ther is still nothing I would try replacing the controller because the infered led's may have gone out.  If that still does not work then the sensor decriptor in the wii has gone out.  Nintendo should be able to help you with that part.  But I do not think that it is the Wii.  I feel that your sensor bar is bad.
Posted on May 28, 2009
barbu51
  • 566 Answers
SOURCE: i can't change the cable channels
Try the 991 code, press tv+ code set+991 then alternate between tv and power stop as soon as the tv respond then press enter , could take up to a 100 try since it goes thru all the codes. have fun
Posted on Nov 02, 2009
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Syma s031
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
No signal to the helicopter
Check all wires to the servos in the copper. They do come loose and get croted, clean your connection and try that, worst case, you may have to replace the servo. Must hobby stores have them.
I hope this helps you
Jan 25, 2014 | Syma S026G 7" RC Remote Control...
My gyro s107g helicopter will not levitate
press the left button(LB(like on xbox controller spot))
Apr 28, 2013 | Syma New Green S107g 3 Channel Rc Radio...
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
I followed the instructions (Brookstone giant remote and Samsung TV) above for manual programming and it worked.... that is it went on. But the volume control doesn't respond and I can't change the...
sometimes there is more than one code that will work for your tv even though its not the right one. Try all the samsung codes even if you found one that worked, try the rest.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Feb 09, 2011 | Brookstone 538744 Remote Control
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
Just bought the Walkera 38 Chinook. First flight I got an inch off the ground and landed it. Next attempt the top rotors spun initially then stops causing them to come in contact with the bottom ones. ...
Sorry for late reply, youve probably sorted this by now. This is common problen, some thing to do with the gyro. If you want to spin the rotors without takeing off the trick is to put full right turn then the gyro tries to compensate keeping the rotors turning at speed. To lift of the trick is to get airborn quickly without raising rotor speed slowly then the gyro will keep compensating and keep the rotors running. Had same problem myself, although saved the gears fortunately.
Hope this helps
Matt
Sep 02, 2010 | Walkera New 38 CH47 Chinook RTF 24GHz RC...
Toys Logo
250 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
