Question about HP Compaq nx6110 PC Laptop
Over heat and freezes - HP Compaq nx6110 PC Laptop
So common reason of over heating is dust and the derailed of cpu fan. you can use laptop on a plane surface to see if it heating due to no air passing to cpu by keep using on your lap
Posted on Dec 30, 2010
Rv heat pump problems
Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-point. There is a sensor that detects evaporator freezing, it may be bad or your freezing because of low freon levels
Sep 30, 2013 | Dometic Rooftop RV Air Conditioner
Heat pump freezing in heat mode
your reversing valve may be faulty
Jan 17, 2013 | Heating & Cooling
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
Pool spa heater when freezing temp
It normally will heat up with pump moving water, once the threshold is achieved - system will come out of its Freeze protection mode and will begin to work as programmed. If there is a heat call, heater will come on.
You can also locate the sensors, both the Water & Air (they need to be very close in temperature for this to work) then place them in water warmer than the actual ambient temp, & above the temp that triggers "Freeze".
Dec 27, 2012 | Jandy Aqualink Rs4 One Touch Control...
What is the difference between freeze-dried and dehydrated food?
Freeze-dried food is quickly frozen and placed in a strong vacuum. This process uses low heat and causes less harm to the tissue, taste and smell of the food. To dehydrate food, heat is applied and moisture is removed through the process of evaporation. This is a low cost method in comparison to freeze-drying.
Jul 31, 2012 | Camping, Backpacking & Hiking
Can you wrap tape around pipes
Yes, you can use heat tape on pipes UNLESS they are plastic or PEX. Copper lines - no problem.Heat tape is used to keep lines from freezing, and generally they do a good job at it, IF you get it wrapped around the part that usually freezes. BUT please understand the design purpose of heat tape before using! For example: My kitchen has an overhang that extends about four heet from the foundation that the water lines run through. In -30 F weather, my water lines will freeze up. I initially wrapped heat tape on the lines below the sink and still had freeze up. So I relocated the heat tape to the crawl space and wrapped the pipe as close to the foundation as I could. That solved the problem.
Nov 29, 2011 | Easy Heat Water Pipe Heating Cable
My vehcle oer heats and leaks anti-freeze
Its hard to figure this one out, without looking at it. pressure test the system pin point the leak, it could be your waterpump. hoses thermostat housing. freeze plugs, head gasket, radiator.
Apr 17, 2010 | 2000 Mercury Sable
Central heat and air freezing up
It is not freezing because it's cold outside,It is freezing due to a problem.
It needs to thawed before it will work,
1st:Check or change the filter if need be.
2nd:Make sure none of the vents are blocked off(especially the return)
3rd:The only way to thaw it when temps are low outside,without being out in the weather is to turn on the air conditioner,You will need to use other means to heat your home until it thaws.
and Please if you use the stove for heating,don't fall asleep with it on.
Jan 17, 2009 | Heating & Cooling
Computer constantly freeze up!
apply heat sink paste in your processor
heat problem
Oct 27, 2007 | Toshiba Satellite A45-S151 Notebook
HP Compaq nx6110 PC Laptop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
