Question about Miele CVA2650 Stainless Steel Espresso Machine & Coffee Maker
I have a Fault F72 on my Miele CVA2660. I have tried removing the Capsule Plate, however it is jammed and I cannot move it. Any suggestions?
2 Suggested Answers
  • 70 Answers
SOURCE: Our Miele coffee machine CVA2660 is showing
F47 Interface between electronics faulty. check connections to electronic boards
Posted on Jun 19, 2010
Removing a jammed capsule - From the carousel tray
well you have to unscrew all the machine until you see the brew unit and remove it i think...thats what i did. Anyway it did it again.....
Apr 02, 2012 | Miele CVA2660 Stainless Steel Coffee Maker
While cleaning Miele built in coffee maker, Fault 17 appeared. What does this mean?
Insufficient water intake. Check that the water tank is installed correctly. Check hoses and connections. Check water tank valve.
Feb 27, 2011 | Miele CVA2660 Stainless Steel Coffee Maker
F14 problem with miele
this fault means low pump pressure in the circulation pump due to foreign particles jamming up the pump. you would need to remove the unit and tip it on it's side and remove the base plate and the pump and clear the blockage.
Aug 26, 2010 | Miele Premier-Plus Built-in Dishwasher
CAN I RESET THE CAPSULE COUNT ON MY MIELE CVA 2660 COFFEE SYSTEM.IT IS SHOWING 3798 -CAN I GET IT RESET TO ZERO ?
No, Not without replacing electronic. You can only reset descale counter in service mode. All other counters are not resettable.
Mar 22, 2010 | Miele CVA2660 Stainless Steel Coffee Maker
Capsules jammed fault 72
I pulled out the pod carousel, and reached by finger over the capsule tray hole. In there was a stuck pod. Once I go that out, I power cycled the machine and all was well.
Mar 03, 2010 | Miele CVA2650 Stainless Steel Espresso...
Fault f72
this is usually due to the hinged part of the capsule plate failing to return to the normal resting position after ejecting the first capsule. You can resolve this problem by occasionally pulling the capsule plate out of the unit and running it through the dishwasher. You can also scrub it with a toothbrush under hot soapy water. Coffee stains build up on the mechanism preventing the plate from dropping to the rested position. The second capsule hits this and jams rather than riding the ramp into the puncture plate.
Feb 21, 2010 | Miele CVA2650 Stainless Steel Espresso...
My machine has died and is showing with error code F 73. I can't find a reference to this error code anywhere. Any idea what this means?
I have had this too...
Try this:
turn off the power (inside opening front) & remove the carousel & runners then the waste container & then the capsule plate.
clean area inside where capsule plate comes from & reassemble everything, that usually clears the problem -if it is only happening once in a while.
Dec 28, 2009 | Miele CVA2660 Stainless Steel Coffee Maker
Machine is giving me fault 71. What is this?
F76 indicates a jammed cartridge. You'll need to clear the jam or call a technician (or a handy individual).
Nov 21, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Miele CVA2650 Stainless Steel Espresso Machine & Coffee Maker Logo
274 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
