Question about Canon Sony DVM-60 Min. miniDV tape - 6Pack Mini DV Tape
Locks on video frames then is fine then skips with bars through video sound is spotty _ the tapes first 10 minutes is great and then the problem- then a recorded hockey game at the end plays fine
    Top Expert:
  • Canon Master
  • 2,931 Answers
Recommend contacting your local service provider directly or online here:
Posted on Feb 08, 2018
    Brigadier General:
  • 8,546 Answers
If this happens on one tape and you get the same video anomalies every time at the same spot the tape is bad.
If it's random and not exactly repeating you could also try cleaning the heads.
Posted on Dec 30, 2010
When I connect the VC500 to the computer and the vcr, most times, the video plays fine. When I try to record, the video skips - it records - but skips and the recording skips as well. It's almost as if...
Hello mabusse
The sofware is too heavy for your computer . You can improve it's function buy setting the quality to a lower level , it will record smootherly but of course the image will be less sharp .
I experienced my self that the best way to succeed in recordong video tapes or tv programs is to use a stand alone recorder .
Best regards ,
fanaudi .
Mar 03, 2011 | Diamond Multimedia ( VC500) Video Capture
Lines through the playback
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Oct 22, 2008 | Canon ZR100 Mini DV Digital Camcorder
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Audio
it is the tape running path makes the problem and normally happens in a long run. realign the tape path by carrying to a sony service centre...
Jan 14, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
On playback, the video has gray lines across it
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Gray lines on playback
Try using an $8 head cleaner for 10 seconds. That might be the solution or if it's a used tape, the speed isn't limked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that.
Dec 26, 2007 | Canon ZR60 Mini DV Digital Camcorder
Picture and sound is skipping or stuttering during playback. It happens when playing any video.
This was often caused by mixing brands of tape. Do not use head cleaners more than absolutely necessary. More than half a dozen times or so, and heads are toast.
Use quality tapes of the same make/length, from new, and you will be fine. (the coatings on the tapes vary, and can/did interact with each other.)
Nov 02, 2007 | Sony Handycam DCR-TRV310 Digital Camcorder
Horizontal bars on playback plus sometimes no recorded picture
Not a solution sorry, but just to note that I have the same problem on TRV30e. It's intermittant an relatively rare, so haven't bothered getting it fixed. Seems related to certain types of DV tapes - if I change tape the problem often goes away.
Oct 28, 2007 | Sony Handycam DCR-TRV30E Mini DV Digital...
Sound skips alot while playing dvd
skipping audio or video on a cd or dvd is generally caused by a dirty lens or a bad disc. . Try a lens cleaner disc and get back to us ?? Thanks Good Luck
Jun 28, 2006 | LGDVT418 System
Electronics - Others Logo
96 people viewed this question
Top Canon Electronics - Others Experts
Are you a Canon Electronics - Other Expert? Answer questions, earn points and help others
