Question about Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
The hot and cold water flow from the faucet OK. However, the separate spray valve shuts off the faucet flow but very little water comes through the hose. The hose isn't plugged as air moves through it freely when you blow on the line. What could cause this malfunction?
    Problem Solver:
  • 9 Answers
Inside the centre spout of the faucet where it sits on the baseplate is a divertor valve. this is not functioning properly and should be replaced. check the delta web site for a break down of parts.
Posted on Dec 29, 2010
Testimonial: "Thank you for the response. I will replace the diverter valve and see if it corrects the problem."
  • dashbeck616 Jan 04, 2011
    The new diverter valve solved the problem.
    Thanks!
Hot water has great flow. Cold barely drizzles out. NOT a water pressure problem. What/How to check on faucet?
Faucet may have scale desposits on cold water side that would restrict flow. The shut-off valve for the cold may not be opened fully. If a saddle valve for refrigerator ice water was installed, it may block off flow for cold water. Check these items first, then ask more questions.
May 11, 2015 | Plumbing
How do i repair bellera #r560vs kitchen faucet reduced/low cold water flow have installed newfaucet valve
Turn off the hot & cold water supply lines at the shut-off valves.
Yo need to use the correct replacement cartridge for the faucet you are fixing
The cartridge replacement procedure requires using food grade silicone lubricant around the base of the new cartridge and around the threads of the bonnet.
Then you must properly align the 2 bumps on the bottom of the cartridge with the inside body of the faucet.
Insert and tighten down the bonnet that holds the cartridge in place to where it is snug- do not over tighten the bonnet!
Then reinstall the trim piece and lever.
Slowly, fully open the hot and cold water shut-offs and check for leaks at the shut offs, sink handle, and spout.
If you are using the Watts brand floodsafe supply lines, turn the hot and cold water shut-offs, on slowly. Rapid flow and pressure may activate the floodsafe valve within the supply line, causing little to no water flow to the faucet.
Feb 23, 2015 | Plumbing
Why don't I have water pressure on the hot water side of any faucets
Most class a mtorhomes have water valves in your water fill bay that have controls for all faucets. There is separate one for hot and cold.
the hot would be turned off for storage to allow you to drain the hot water heater for storage.
there may be hot water valve for all faucets or one valvefor each faucet.
Jul 21, 2014 | Itasca 2008 Ellipse 40WD
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
Had new water heater installed. Ever since, there is very little water flow from both hot and cold faucets of both (dual) sinks in 2nd floor bathroom. Faucets are Moen 9000 M-PACT type. Could air be t
check the aerators on the faucets. i know after i change a hot water tank there is always some crud that comes through the lines and gets stuck in the aerators, they are the part that holds the screens in place on the spouts.
Aug 14, 2012 | Moen Plumbing
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
114 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
