My RDR-VX535 DVD/VHS player displays "DVD 3" whenever I press a button on the remote and won't respond. How do I fix this?
    Genius:
  • 1,622 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons
I hope this will help in solving the problem...
Posted on Dec 29, 2010
Vhs to dvd - "simple dubbing" greyed out, help please thank you!
check your software, what are you using???? Free software is available at Burnworld.com
Mar 06, 2010 | Sony RDR-VX535 Player
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Accidentally reset from DVD3 to DVD1...Now nothing will work including the remote control...Is there a process to change it back?
Press & hold the Enter button. Then press & hold the number 1 for a few seconds. Release both. Now, press the System Menu button. You should have access to the system menu.
Aug 25, 2009 | Sony RDR-VX535 Player
Can't get my sony RDR- VX535 out of the 2 mode. remote will not operate the recorder. i perchased this unit used on ebay. it played fine until i got it out of wack the remote with this unit is a sony...
*Take the remote away from the player. Then hold the enter button and the code* 1 or 2 down for 3 sec. and then you will get some use and you can reset factory defaults. Then repeat from * to * reset for code 3. Hope this works for you.
Jul 28, 2009 | Sony RDR-VX535 Player
I have Sony RDR-VX535 and suddenly every time I press the remote it reads DVD 3 and does not perform any of the functions that I requested.
Your DVD recorder is set on DVD-3 remote option, check DVD Recorder remote lower section for DVD Mode button that has 3 options, set it on DVD-3 and recorder will start responding on your commands of remote.
Jul 10, 2009 | Sony RDR-VX530 DVD Recorder/VCR
The RDR-VX535 does not transfer the 1:33 aspect ratio from VHS to
Did you try the unscaled option, that sould fix the issue.
Apr 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
