Question about TruTech TT320
TT320 DOESN'T WORK
The eject doesn't work with or without a remote. The unit has totally failed. I know it wasn't expensive, but I've had it less than 1 year!
  • Anonymous Oct 14, 2008
    Couldn't get the eject to work. Tried both the remote and the button on the player. This is yet one more reason I'm not impressed with TruTech's player..
Fyi... If you don't flip unit over very slowly and carefully, your DVD will flop out of the drawer, and float inside of the unit. It happened to me and it was a big pain to open the unit to get the DVD.
All in all, tho, the unit is dead. And I only used it about 10 times. It is junk!
Posted on Sep 07, 2008
If your disc is still inside, flip the unit over, and insert a pin where it says: "For ejection insert a pin (and) push to left". Once you have done that, slowly and carefully flip the unit rightside up, and pull out the disc tray. Then take out your disc. If you disc gets stuck behind the tray for any reason, pull the disc tray out of the machine. This may require a bit of stregth. once this is done, take your disc out of the machine and then insert the disc tray back into the DVD player.
Posted on Jul 14, 2008
SIMPLE....THE TRUTECH WENT IN THE TRASH AND I BOUGHT A NEW DVD PLAYER.....END OF STORY!
Posted on Jul 09, 2008
1.5 and 2 pounds button doesn't work
I'm very sorry you are having to deal with this issue. Unfortunately, there is no user serviceable parts. It seems that your key pad is failing/failed. The unit is 5 years old. You might try taking back to Walmart, their return policy is quite liberal otherwise, you will need to contact the manufacturer directly to see what the cost of repair would be. I hope this helped.
Dec 20, 2017 | Black & Decker B2300 Bread Machine
My APC ups doesn't power on
If your APC UPS is new but was stored unused for awhile, the battery may have discharged completely. You may find a comparatively less expensive and less time consuming solution is replacement.
Feb 22, 2013 | APC Smart-UPS® XL 2200VA (SUA2200RMXLI3U)...
When we turn the power on iit only stays on a few seconds then turns off with the cst.in light flashing.. what does this mean and what can we do to fix it?? tks
I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one! Good luck!
Jan 17, 2011 | Emerson EWD2202 DVD Player/VCR
The cst.in function on my dvd/vcr is blinking and because of it, i can't work my dvd/vcr. What can i do to fix the problem?
Jan 16, 2011 | Emerson EWD2202 DVD Player/VCR
It does'nt turn on don't respond any comand The
I had a problem similar to this. I fixed it by toggling through the top buttons on the remote control. Sometimes the wrong button gets pressed and the remote cannotcontrol the unit it is supposed to. i.e. make sure TT320 remote has good batteries and then make sure if it has other buttons on it like TV, cable, DVD etc that the correct one is pressed to control the TT320. My TV remote would not control my TV and by chance my kids had pressed the satellite button so I had to press the cable button and then the controller startedto control the TV again.
Nov 02, 2010 | TruTech TT320
My remote is missing
If you have symbian mobile like Nokia 6600
which must have Infrared
use the software total remote irda
If you want me to give you Please contact me
Ali.raza747@gmail.com
But first VOTE 4 ME
Sep 26, 2009 | TruTech TT320
4x4automatic: stuck in 3rd gear from start.
It does not make a difference if the kickdown cable is out of adjustment. If the cable is out of adjustment, the jeep simply won't shift into higher gears, but it will always start in first gear. I believe that the tranny has been neglected and not had an oil change(before you did it)in a long time. The clutches in the tranny will fuse together and give you your simpton.
Dec 05, 2008 | 1991 Jeep Cherokee Limited
Tru tech tt320 dvd player
When I install a disc my monitor indicates "loading" for a few minutes then "no disc" for several before the floating "dvd" appears. Meanwhile, on the remote, except for the "off/on" and "eject" buttons, no other button works. Please copy youngruss@aol.com on your response. Thanks
Jun 08, 2008 | TruTech TT320
Trutech TT320
"Hide" the remote and try to operate the unit using the front panel controls. Does this work? Then the problem is the remote...accordianman
Feb 18, 2008 | TruTech TT320
TruTech TT320 Logo
218 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
