Question about Fuji FinePix A920 Digital Camera
Hi...when i try to take photo camera shuts down leaving lens unretracted
Hi...when i try to take photo the camera shuts off
Posted on Feb 25, 2011
Camera can't take photos
Most of the time, when a camera asks to shut down there is a problem with the camera. Could be the lens can't come out complete or other, almost invisible things. Even the battery can be a bit low, so as soon as it wants to make the camera ready to "shoot" the voltage goes low. Lots of cameras, will go off then. If you can't find any obstruction on the lens, please charge the battery and try again.
Nov 27, 2013 | Panasonic Lumix DMC-LS70 Digital Camera
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
Sanyo S770 lens won't retract on shut off and shuts down when try to zoom and get lens error
Lens error happens during the lens guide pin wrong movement. Please try these below and let me know.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 06, 2011 | Sanyo Xacti VPC-S770 Digital Camera
Camera shuts down when 'zoom lens' is used.
Hi there please follow the steps and let me know the result.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 24, 2009 | Canon Cameras
Camera turns on and then shuts down leaving the
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 13, 2009 | Sanyo Vpc-s1070w Digital Camera
Buzzing sound, wont come on!
Don't try and manually push in the lens at first...the buzzing is a warning letting you know that something is wrong with the camera. By accidently removing the batteries during shut down you interupted the shut down sequence. Try and turn on the camera and immediately press the play button on the back. This should reset the camera. If not and if you are under warranty it needs to be serviced. If you are not under warranty then you can try and push the lens down. Don't use a lot of force but try and gently do it.
Jun 09, 2008 | Cameras
Canon A75 stuck between ON & OFF after uploading photos
My Canon A75 has the EXACT same problem. I have always handled it with care. When I was taking photos with it, the camera suddenly started shutting down without a low battery warning. It just started shutting down, but it stopped with the lens still sticking half way out. Like yours, the top green light flashes when I try pressing the power button. Any ideas?
Dec 16, 2006 | Canon PowerShot A75 Digital Camera
Fuji FinePix A920 Digital Camera Logo
121 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
