Question about Aquabot Turbo T2
How do i correct my turbo from going in circles
Good day,2.2 2014 5 spd box twice in one week my i light circle came one and then no turbo??101164 km on bought vecichle a month ago and blown gearbox two weeks ago any help
what maker of vehicle
ecu will have fault codes to be read
loss of power on a turbo can mean many things
very complex systems
turbos and gearboxes do fail.....thats a fact
Mar 26, 2017 | Cars & Trucks
Torque specs &and sequence for a 2011 chevy cruze 1.4 turbo head
26 lb ft and aditional 180 degees the secuence is from the center go on circles to the out side
Jul 17, 2015 | 2011 Chevrolet Chevrolet Cruze ECO
Can we disconnect turbo?
if you remove the turbo from that car, the car will not run very well because the computer is setup to run with a turbo device, it need the air flow to force the fuel where it need to go. after removing the turbo you are going to have fuel issue, stay running, be fore you buy it go to the owner ask if they would mind if you or them disconnect the belt from the turbo charger and restart the car, see how well it runs, try and drive it, if every thing works okay, than buy the car and leave the belt off the charger.
Feb 04, 2014 | 1996 Volvo 850
Tubro was making 40lbs of boost, now only 20 what's going on
turbos generate boost fro the heat in the exhaust and the free flow of exhaust gases. That means the amount of fuel through the injectors and blocked cat converter or exhaust system. OK now you know how the boost is generated look for areas that will loose the pressure (boost ) between the turbo and the manifold Look for loose boost hose clamps on the turbo and intercooler and intercooler and manifold. Look for cracks or holes in intercooler. Look for blocked air cleaner as turbos use more air through the air cleaner than normal. Finally look at the compressor blade of the turbo as any bent fin will slow down the turbo wheel giving less boost. Have the turbo tested for correct operation
May 10, 2013 | Cars & Trucks
WHISTLING BELOW TURBO
Its surely not turbo, its is somewhere a hole or leak in turbo air filter housing or air inlet pipe that is making noises when turbo sucks air. check the air pipes wheather they are fitted correctly. Take a keen look at air hose and close any hole with silver tape check the hose is fitted correctly in Turbo air filter housing (if not then it makes whistling noise when air is being sucked by turbo) . Clean all air filters and then give it a go.
May 07, 2009 | Peugeot Liberte Cars & Trucks
Where do you put the two little springs, and what do they do? My blades have started to rattle on clipper. Oster turbo clippers.
The springs probably go with the carbon brushes, to hold them in. To find the brushes, use a dime to unscrew the two circles on the side of the clippers.
The rattling could be from loose screws on the blade hinge. My turbo clippers did the same thing. The blades rattle if the screws are even slightly loose.
Nov 12, 2008 | Oster 76076-010 Hair Trimmer
Turbo c++ programming is not working
If turbo c++ is placed in any other drive than c drive then u hv to provide correct path by going through Option >>directories>>Library Directories and provide exact path where ur turbo c++ is placed.
Oct 06, 2008 | Microsoft Windows XP Professional With...
Aquabot Turbo T2 Logo
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
