Question about Casio CTK-720 Electronic Keyboard with Stand, AC Adaptor and Instructional DVD
I need to instructions on how to put together the stand
Blue LCD screen
I had the exact problem, mine was a YPG 535 brand new in box I put everything together with stand and FC4 pedal. When i got ready to play just a blue screen and none of the red lights came on and no sound, I notice when i was messing with the on and standby button hopeing it would work the speakers would make a popping noise I personly thought it was a manufacturing defect.....i'm sending it back to have it replace. I never had problems with yamaha products but seems like more and more defects are happing with newer portable grand series!
Feb 24, 2014 | Yamaha DGX 640 Keyboard Arranger
Manual in english for bassoon stand
Here is what it should look like when put together. Can't find any manual for it, though.
http://products.k-m.de/us/product?info=863&xd4765=b4bg1t2hp76a3r5di251v72p65
Mar 03, 2013 | Meyer Konig and Bass Clarinet Bassoon...
Cant put casio 210 tonebank on its stand
What type stand is it?
Feb 21, 2013 | Music
Can't connect my ctk-720 to my mac
The Mac needs the driver, and you may need to select it in Chooser as well. If it is not on the instruction disk, it should be downloadable from the manufacturers website.
Sep 25, 2012 | Casio CTK-720 Electronic Keyboard with...
Keyboard stand by casio seems to have no support to hold the keyboard. The keyboard slides from side to side on the stand
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
Apr 01, 2012 | Music
I have 2 th-15a and went i put them to sound together trere is a big humming sound. i dont have a mixer and if i need one witch one should be
Make sure ALL interconnected equipment is powered from the SAME receptacle. Use extension cord if necessaary. Use ONLY balanced interconnecting audio lines as well. You have a ground loop... make sure all power connections are three wire.
Jun 23, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Proline Piano Keyboard Stand Assembly Hi, I just bought a Proline piano stand for an electronic keyboard, and the first step on the assembly directions is to move the clutch to the middle position....
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Nov 28, 2010 | Pro Line Proline Pl 400 Double X Braced...
Assembling Odyssey Lstand
lol....after reading your problem and then posting mine I had an idea. I went to youtube.com and found out that in order to hook up the U CLAMPS...you have to disconnect the table top attachment and connect the U Clamps to the short bases. You then dont need longer screws you use the little black screws that came with the stand. I went to Guitar Center after I did mine and confirmed that theirs was set up the same way....lol...LETS PARTY NOW !! This calls for a celebration party...lol GOOD LUCK AND TEAR THOSE PARTIES UP
Jan 28, 2009 | Odyssey Lstand Laptop Stand
Casio CTK-720 Electronic Keyboard with Stand, AC Adaptor and Instructional DVD Logo
366 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
