I have a Konica Minolta c450. How do I print test pages to check imaging unit colors.
  • Gail Williams Dec 30, 2010
    Thank you for the reply but your response was not exactly what I was looking for which is my fault. Let me be a bit more specific. I am trying to find out how to test print each individual color so I can check the quality of my imaging units. I had a tech over once and he did something that made my copier print one test page in black, one in cyan, one in yellow and one in magenta. Again, it's for the imaging units. Thanks.
    Your answer was exactly what I needed. I have even saved the link for future references. Thank you very much.
  • 903 Answers
Hi, you can print a test page from your computer by doing the following:
- Right click the c450's icon in the Printers folder and choose Properties. - Under the General tab, select either "Print Test" or "Print Test Page."
The test page will print out and you can check the printer's operation.
Posted on Dec 30, 2010
  • 1 more comment
  • gggg Dec 30, 2010
    You can also print a test page right from the printer:
    - Press the Utility/Counter button.
    - Select #2, User Setting.
    - Select #6, Printer Setting.
    - Select #5, Print Reports.
    - Select Demo Page.
    - Choose a paper tray to print from.
    - Press Start.
  • gggg Dec 30, 2010
    By using the web page below, you can print out a test pattern for any of the four colors (or combinations of them):
    http://www.inkguides.com/page-print-test...
    Scroll down to the section titled Printing your own printer test page and look at #4-7. Clicking on the link for a specific color will bring up a test pattern that contains only that color, and from there you can right click on the image and select "Print." If you want to save paper, you can use #2 -- "Print test page (CMYK)" -- to print each of the four colors all on the same page.
  • Escaner Decop
    Escaner Decop Jul 07, 2014
    thak you great answer
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
KONICA MINOLTA 2400W PRINT BLANK PAGES
Verify the drive transmission mechanism to developing unit,the image transfer current terminal and the scanner drive transmission mechanism.
Feb 13, 2013 | Konica Minolta magicolor 2400 Laser...
What is error p-21 of konica minolta bizhub c250?
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
I have a Konica Minolta bizhub C450. Can the image unit be reset?
It may, but this mean that next time you put toner on the machine, you will expect less copy quality and printing for each toner bottle.
Dec 23, 2010 | Konica Minolta bizhub C450P Laser Printer
Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Mar 02, 2009 | Konica Minolta bizhub C450P Laser Printer
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
628 people viewed this question
k24674
