Contributor
- Posted on Jan 17, 2011
Re: The water hose got cut in half.
I had the same issue when a friend tried to use mine - if you remove the top plate, you can then lengthen the hose as there is an extra bit of tubing. It should be enough to reach the bottom of the water container again. You can then attach the filter from the severed half.
