Heater cant get fuel to ignitor. replaced round disc in pumpo old one broken. sealed pump with gasket glue . this is a reddy heater model a55bt.
  • 674 Answers
Check the air pressure. Also check the fuel filter and the nozzle to make sure there is no blockage. The air pressure should be 3.4#.
Posted on Dec 30, 2010
Reddy Heater 170T works fine with the cover off but will not ignite with the cover on.
First, heaters with Hot Surface Ignitor technology MUST have the air pump pressure set to factory specs. The onboard computer will not allow any deviation. Proper fuel delivery depends on it.
Now, if the pump pressure is correct, there are no leaks between the pump and the nozzle and no vac leaks on the fuel line, the 90% of the time the problem is a worn nozzle. Desa recommended annual replacement of the nozzle simply because of the wear factor.
More troubleshooting tips
Oct 31, 2011 | Reddy HEATER RH170T 165,000-BTU PORTABLE...
Reddy heater starts fuel sprays and ignitor glows then it shuts down without starting flame
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 28, 2011 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 60kbtu will run a few minutes and quit. Maybe 3, maybe 5, maybe 30. Photocell checks good, cleaned tank, replaced filters and cleaned nozzle, replaced plastic end cover. still makes bubbles...
You may want to replace the gasket to get a good seal to draw fuel with out air. You could try a gasket eliminator and seal this thing back up. A good auto parts store also sells gasket material where you can make your own new gasket, you need patience and a sharp knife and a punch for the holes.
Dec 28, 2010 | Reddy Heating & Cooling
I have a Reddy Heater Model R110. It has operated great until it ran out of fuel. I filled it up and now it will not ignite. It is pumping fuel as fuel is running out the front of it. I cannot find my...
remove the cover and check for spark at plug when plugged in if no spark check spark plug gor proper gap, or defective transformer electronic ignitor if you see spark check for proper pump pressure and restricted fuel flow due to seal leak, filter blocked and restriction in nozzle. I would check for defective photocell first for soot/dirt if dirty wipe with clean damp cloth remove photocell from heater and connect ohmeter on the 1000 ohl (rx1k) scale. Hold the lens up to a light source (60 wtt bulb, with the lens of the photocell pointed towards the source the resistance of the meter should be low by clocking off the light source by putting thumb over opening of cell the resistance on meter should be high, replace photo cell if a change in resistance is not observed during this test, let me know if you need more assistance
Dec 07, 2009 | Reddy Heating & Cooling
Ignitor lights, fan comes on,wont start ,has new fuel,
My guess is that your statement "won't start" refers to the flame (lack of). If this is the case then ask yourself if the unit is getting fuel. If NO fuel, check the pump rotor- it may be broken. If SOME fuel, then set the pump pressure. Air pump pressure is directly relayed to proper fuel flow. Instructions http://www.reddyparts.com/pressure.htm
Nov 03, 2009 | Reddy R60A Utility Heater
No start i cant see ignitor get brite red dont seem like im getting fuel
If the ignitor isn't glowing it isn't a fuel problem. It may be a pressure switch or bad ignitor.
Oct 04, 2009 | Desa International Reddy Heater R40 40,000...
Not getting fuel after air and fuel filter maintenance.
If the maintenance procedure included anything that required you to dis-assemble the air pump then you must simply re-set the pump pressure in order for fuel to be pumped into the combustion chamber. . It's an easy procedure. Instructions for setting the pump pressure
Feb 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
NO FUEL AT NOZZLE
FOUND THAT THE FUEL HOSE AND AIR PUMP HOSE HAD BEEN REVERSED AT THE NOZZLE-PUMP HOSE NEEDS TO BE CLOSEST TO THE BLOWER HOUSING-I USED A VAC GAUGE TO TEST THE FUEL LINE-WHILE THE AIR PUMP WAS RUNNING-NO VAC-REVERSED LINES AND STARTED UNIT-ADJUSTED AIR PRESSURE-ALL IS WELL
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Dec 16, 2008 | Desa International RH125AT Utility Heater
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
