Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Unit is leaking out of the bottom of the housing
    Problem Solver:
  • 16 Answers
Deep six it & start composting
Posted on Dec 30, 2010
Garbage disposer leaking at bottom
Since you have checked all pipes and see no leaks next please check the area around the top and bottom of drain housing. If that's not leaking there is a gasket inside the disposal that could fail and cause water to leak into the motor area and then leak through the bottom of the unit. Generally in my experience replacing the whole unit is a time saver because access to that gasket is a pain and finding the right gasket can be timely. Depending on how old the unit is I would just replace it.
Jul 06, 2017 | Electrical Supplies
Water leak from bottom of unit
Loose/broken clamp or drain hose. Fill hoses attached to fill valves or leaking pump housing.
Jul 29, 2014 | LG Washing Machines
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Our Fisher & Paykel single dish drawer unit (6 months old) is leaking limited water from its base down the front of bottom drawer below the unit's base onto the kitchen floor. One inspection by a...
One drawer leaks can cause this problem. If you don't fix it. One day it will turn on the pumps from both units without any one touching them since the floor sensor at the bottom housing detects water and it will run for ever until you unplug the power cord. This dishwasher is a state of art in design and replacing parts is very simple once a person has enough understanding of its mechanism. If the tech fail to find the problem then he is not qualified to touch this dishwasher. When there is a leak, it is a problem with the lid seal from the top not closing down tightly so during the wash cycle, water shoot up and leaks through the top opening then collecting on the bottom housing of each unit. Let say the top draw is leak, so the bottom housing of top draw if full of water then it overflows to the bottom drawer unit then the floor. Here is the idea of how it happens. The top lid is pulled down by 2 actuators from both sides at first start. That is why you can hear the motor noise turning on at the beginning of the wash cycle. That is the noise from the actuators. If the actuators are bad. only one side works then the lid can not be sealed properly there is a leak. If bothe of actuators are week the gear worn out so they can not hold the lid down during the wash cycle then it can cause a leak. You can pull each tube out and access from the left side at the bottom to touch the bottom housing to fell the wetness. Put in tower to dry them out. If there is a weteness from the bottom housing upper tube it doesn't mean the bottom drawers is leaking. It is wet just because the top is leaking. However you have to dry the bottom in order to continue use the bottom dryer. If you ignore my advice then your circuit board at the bottom housing of lower drawer will be damaged and it is not cheap. With the information that I provided you can interview a tech claiming know about the this type of dishwasher before letting him coming into your house. Good luck.
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Condensation leaks out front of unit into the house.
Hi, no don't drill holes in bottom tray, to make drain, that's design, you need to keep water there, the fan usually pick up water(moisture) and add to your air inside your home, otherwise the air in your home will become to dry, dry air will create static electricity all over your home, from your carpet to your clothes, you need to level your unit horizontally, put a spirit level, and you should have a slight pitch, from front to back, good luck.
Aug 03, 2009 | Maytag M6Q10F2A Air Conditioner
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
53 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
