Question about NetGear WGT624 Wireless Router
Reset the router
By mistake I reset the router.I lost the network set up.How can I set it up again??I don't have a CD or anything. Thanks for your attention.
  • 298 Answers
You can configure the router via the web user interface. You access this by opening your browser on the computer that is wired directly to the router. Then type in the address bar or By default the username is admin, and the password is password. Click the Ok button to log in to your router. Now from here you can set it up for internet connection and configured the wireless settings for the wireless connection. Let me know if you need more help.
Posted on Jul 07, 2008
Forgot my password for wireless router 660hdt password for zyxel 660hd
There are two different things. One is the Login/ Password to log in to the router user interface for configuration. Second is the Network Key, which you have to provide to get access to the internet. If you have forgotton the Network Key and know the login/ password, you can log on to the router settings and reset the Network Key.
In case you have forgotten the login/ password of the router,
You may reset router to factory setting from the reset button on the back side of the router. It may be a push button or else use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
. Configuration may be tricky sometimes and you have to secure the network/ router.
Hope it helps! Good Luck! Thanks for using Fixya!
Oct 16, 2011 | Zyxel (91-004-361002) Wireless Router
I have d-link router ,works fine ,my new laptop hp don't connect to interent ,see the network ,but unable to connect
Hi amany91,
There might be an issue on your wireless connection security settings. I would advice resetting your router to remove the password and to restore to factory settings. To do that, look at the back of your router and look for the RESET BUTTON. Then using a pin, press and hold the reset button for about 10 seconds. After resetting it, restart your laptop and then try connecting to your router again.
You can rate my answer if you appreciate it.
ternet again.
Oct 09, 2011 | D-Link DIR-615 Wireless Router
Sir i lost my wireless network name and wireless network password
Hello Leonard,
You can just reset your wireless router to restore factory settings. If you reset it, your network name will be back to DLINK and you won't need any password. To reset it, look for the reset button usually found at the back of routers. It is a small button inside a small hole, so you will need a pin to press and hold it for about 10 seconds.
Don't forget to rate.
Sep 22, 2011 | D-Link DIR-615 Wireless Router
How can I reset my router if I don't have the CD
you can reset the router by using the reset button found at the back port near the DC power jack. happysnapz.gif
you may need to push it using a tip of a pen or anything pointed. just hold it down for about 5 seconds. light indicator will turn off and on again signifying that the router performed a reset.
Aug 27, 2011 | Linksys WRT120N Router
I set up wifi network in my home and forgot the password I used to set it up. Is there any way to recover that password?
Unfortunately, no. The only way to access your network again is to reset the router by holding down the reset button on the back (you might need to unplug it, then plug it back in while holding the reset button). That will reset your web interface (navigate to in your browser while connected to the router)'s username and password to some form of the following:
Username: admin
Password: admin
Username: admin
Password: password
Username: admin
NOTE: The last combination is a blank password.
Once you've entered your router's web utility, you can set up your wireless again. Don't forget to write down the password...I wrote mine on the router itself, because honestly nobody can see it because it's in my house, so I don't have to worry about it being stolen.
Jul 27, 2011 | Linksys Wireless-G WRT54GS Router...
How can ifind the wep key?
If you mean when you've lost it, forgotten it, you can't. You'll have to reset the router and set it up over again. Most routers are reset by putting a pin in the hole to reset it. Some have a reset button. When you do it's a good idea to write the wep key on a piece of tape and tape it to the bottom of the router so you don't forget it.
If you mean find it in the set up... after you get it set up and go to log in and pick a network it will pop up when you select your network. It will show it as secured then you can put in the web key. .
Apr 23, 2011 | Computers & Internet
Password retrieval. Cannot remember the password and I need to hook up a new Mac computer to my wireless network with my Cisco Valet M10 router but do not want to disrupt my current hardware. Thanks
it has a reset switch at back u have to reset router back to factory settings
use the manual for more details and password
then after resetting the router you have to again configure its setting as your needs
Once you reset the router your configuration will be lost and you will have to re configure it
Jan 07, 2011 | Computers & Internet
Lost cd d link 624
Are you trying to access the router over wireless? If so, I suggest you try using a cable instead. The router would have come with an ethernet cable (it may be blue). Please plug one end into your network card on your computer and the other into the router. After both ends are plugged in you should see a new light on the route come on.
Then open your browser, and go to and see if that brings up the page.
If this does not work, please reset the router to its defaults by using the reset button on the back --- while the router is on, press AND hold in the reset button for about 15 seconds. Then you can to access the router again.
Please let me know if this helps or if there is anything else I can do. Thank you.
Sep 21, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Input of incorrect WEP settings on notebook
There are 2 things you can do. One is to connect the router to the notebook via ethernet cable. You will then be able to enter the router's page by typing The other option is to reset the router to its default factory settings. This is done by pressing the reset button on the back of the router and hold it down for 30 seconds with power still on.
May 10, 2008 | Belkin (F5D5231-4) Router
How to reset a linksys router
On the back, there is a small hole with "Reset" over the top of it. Inside there is a pushbutton switch. I believe you disconnect the power and hold the switch in for 30 to 60 seconds. This will reset the router to the factory default settings.
Mar 15, 2008 | Computers & Internet
NetGear WGT624 Wireless Router Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
