Question about Linksys Wireless-G WRT54G Router (DSLSWRT54G)
I can connect to the internet via a hardline from my modem but via my router i can only connect to the network and get no internet access how can i fix this?
    President:
  • 1,102 Answers
Hook up your router and then start up your web browser and type 192.168.1.1 into the address bar. A pop up window should appear and it will ask for a user name and password. Leave the user name blank and type "admin" in the password. Once you have done this, you should be able to access the settings on the router. You did load the software right?
Posted on Dec 29, 2010
Wifi connectivity issues
Can you see the signal strength tree, (bottom right of desktop). If you select your address and insert your router code, it should work. I don't think it is drivers as the connection only is down to the drivers.
Reboot the router when you are satisfied all is as it should be.
Dec 22, 2013 | Toshiba Satellite L305D-S5974 Laptop
What should be the "properties" settings for wireless network
If you have a wireless router and you want to setup a wireless network so your computers can share data between computers and access the Internet via a DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jan 16, 2012 | Toshiba Portege 2000 Notebook
What do I need to connect the PS3 to the internet so my boys can play online ? Hardline or will WIFI work ?
Any of the two will work it all depends on preference. If the modem or router is too far from the console then you would most likely want to go wireless. Here are instructions how to do each:
WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
No internet
Power down your modem and router by unplugging them. Wait 30 seconds. Plug your modem back in and let it cycle through. Wait until it's fully connected. Plug the router in and let it cycle through. That should fix your problem.
Oct 29, 2009 | Belkin Wireless Cable/DSL Gateway Router
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
