FixYa.com
Tags:
Vacuums
Generic problem for all Bissell Vacuums
Replacing the brush drive belt
posted by lmeyers7 on Jul 07, 2008
replacing the brush drive belt on model #1697 carpet cleaner
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 07, 2008
Not Rated (0)
ginko
Rank:Guru Guru
Rating: 87%, 723 votes
Comment by ginko, posted on Jul 07, 2008
Here is also the manual for bissell 1690, very similar to your model.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
The Machine
Rank:Wiz Wiz
Rating: 84%, 233 votes
To replace the Brush Belt:
You will need a Phillips head screwdriver.
1. Turn the machine OFF and unplug from the wall outlet.
2. Step on the release pedal to lay the handle down on the floor.
3. Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
4. Turn the machine over to expose the brush.
5. Look for the red retainers, which hold the black brush arms and gear-type brush belt in place. Unscrew the two Phillips head screws. Set these parts aside.
6. Loop the replacement brush roll belt around the brush end and the red pulley with the ridges.
7. Alternate holding each brush arm in place while replacing the red retainers.
8. Replace the Phillips head screws and turn until snug.
9. Turn the machine right side up to replace the Tank-in-Tank and SmartMix Bottle.
If you require additional assistance, please call BISSELL Consumer Services Toll free at 1-800-237-7691 Monday through Friday from 8 a.m. to 10 p.m. or Saturdays from 9 a.m. to 8 p.m. ET.
This Problem Also Relates To: Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Bissell 9200 Upright Vacuum Bissell 8910 ProHeat Clear View Upright Vacuum Bissell 12005 Spot Bot Handheld Vacuum Bissell 1685 PowerSteamer Vacuum
Can you Help with these Vacuums problems?
Vacuums
Dyson dc16 handheld vacuum...
Dyson dc16 handheld vacuum... Answer This...
Hoover SteamVac F5914-900 SpinScrub Upright...
Making a loud screaing noise
I used the unit about two weeks... Answer This...
Dirt Devil CE6000 Featherlite Wet/Dry Vacuum
Water Leaking
My CE6000 leaks water profusly... Answer This...
Vacuums
does not work - how
does not work - how would I... Answer This...
Vacuums
Where is the power belt
Where is the power belt on a... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
