Question about Dell Computers & Internet
On the computer where you would put in games and music CD its not reading the disc. what do i do?
  • Dell Master
  • 27,725 Answers
first try another disk in the drive and see if this one works if it does the games disk might be faulty if it does not work
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 29, 2010
Cd recorder won't read blank cd
If it is a older CD Recorder, You have to use disc,s that stay music on the label. Disc,s for burning music from a computer will not work in them,
Dec 04, 2012 | Tascam CC-222mkIII CD Player / Recorder
Cant play computer disks such as pictures
Computer disc are written in a format that PS3's read, if you want to play photos or what not you need to burn your disc using like Nero or Power DVD to say the least, you need to select picture CD not DATA or otherwise.
If your doing music you need to burn using make music CD not just drag and drop.
Try burning using picture CD format then update me with any questions you may have or problems that may arise from this solution.
Hint!
If you got a SD CARD you can put the photos on it and the ps3 will pick those up just fine!
Let me know how it works out.
Thanks
Ed aka rulds2008
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
I was just wondering, IF the PS2 can play games that have been edited on a computer/laptop (e.g. 4-disc PS1 game put onto one disc), and not edited as in the actual game disc being edited, but put on a...
Your system needs a mod chip to play games on a disc that was not created by Sony.
Most ps2 games are DVD's only some are cd's.. All of the ps1 games are cd's so if you burnt it onto a dvd its not going to work.
Oct 06, 2010 | Sony PlayStation 2 (PS2) Console
MY Macbook pro disc drive wont read the Starcraft game discs. Every other cd or dvd i put in the drive at least reads, but when I put in starcraft it just spins for a second, pauses, and spins again...
I was pretty disappointed when I couldn't play a 12 year old game on my new macbook either. The best thing to do is go to battle.net, load up the CD key and then load the software onto your mac. The downside is that you will need internet access before playing even if you play single player. That's the way I got around it.
Apr 11, 2010 | Blizzard Entertainment StarCraft Battle...
Put in disk in 360. Play Playonline viewer, but screen goes black, and says cannot read disk, need to clean or restart. I did this several times and same result.
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
Dec 26, 2009 | Square Enix Final Fantasy XI for Xbox 360
Sims Life Stories wont download HELP!
If still the CD Drive cannot read the Disc then you should another CD Drive if this game is still working or read. CD Games Disc cannot be easily damage or broke even you keep it in a long years.
Try another CD/DVD Drive to run the game or Use another Computer to see it is still work.
Sep 02, 2009 | Aspyr SIMS LIFE STORIES for Mac
DVD drive won't recognize discs
Does your cd drive show up in my computer?
for a game disc, you dont need any codecs at all to run it. those are for recognizing certain formats of video and audio usually found in downloaded musics and movies. let me know.
Apr 26, 2009 | Computers & Internet
Ps2 slim not reading discs
You can buy new DVD pickups online for about 15-20 It will take a very small phillips screwdriver and needlenose pliers to change out the old one
Mar 22, 2009 | Sony PlayStation 2 Slimline Console
Wont read games
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys.............
Mar 03, 2009 | Microsoft Xbox 360 Console
Playstation 3 wont read some cds or play downloaded demos.
I'm also having this problem as well, it has to do with the OS and it is corrupted. It seems like the "Game mode" has been corrupted preventing us from playing games on the hard drive or reading games.
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
