Question about Planar PR3020 DLP Projector
Planar PR3020 light turns off right after startup. Projector starts up just fine but within 10 secondsthe light goes dark. The fan starts up and I can still feel air movement even after the light goes out.
2 Suggested Answers
incent111
  • 16 Answers
SOURCE: Mac mini and Planar PL2010MW contectivity
have you tried changing the display resolution to lower at first so you can at least get a signal ?
Posted on Mar 23, 2010
When I turn my projector on within seconds it turns itself off
Are the fans all starting up? The symptom you describe is often associated with a faulty fan. Also could be a failed lamp, as the projector will shut down if the lamp does not strike within a defined time, although in this case the 'lamp' light should come on
Mar 31, 2014 | Sony VPL-CS7 Multimedia Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Just replaced bulb when cold it has trouble lighting.
it's not the lamp, it's the ballast. when it's fully discharged, it needs too much power to start. once it has the caps charged (when it's been running and warm), it'll start right away. it sounds as if the capacitors on the ballast are drying up. best to replace the ballast. after you do, make sure the projector is free of dust and dirt. excessive dust will cause premature power and lamp failure due to lack of cool down.
Jul 07, 2009 | Sharp XR-10X Multimedia Projector
Dec 27, 2008 | Planar PL2010MW Monitor
LV-S2
Sir, The ballast unit of the projector is faulty which gives supply to the lamp unit. Open and check the smps with Ballast unit.
Mar 28, 2008 | Canon LCD PROJECTOR Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Projector will not fully startup
the colorwheel is bad. and what's worse, you can't get parts for the lp340 anymore.
Dec 01, 2007 | InFocus SP-LAMP-LP3F Projector Lamp for...
Blub goes out during use.
Most fans have a sense line to detect the fan is working properly, Possible the sense circuit has failed. The unit should not start if it thinks the fans are not running. Possible thermal problem with the sense circuit, since your unit starts up then stops.
Mar 10, 2007 | Toshiba TLP-ET1 Multimedia Projector
Planar PR3020 DLP Projector Logo
44 people viewed this question
Top Planar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Planar Office Equipment and Supply Expert? Answer questions, earn points and help others
