HP 1200inktjet error 00D4-C3F9 firmware error
  • 7,733 Answers
How to FIX HP CP3525N PRINTER THE CODE :49.2 FA7 ERROR
Error 49.2 related to 'firmware'.,Download the firmware from hp site, up load it as specified.Pl read "read file" carefully before uploading the firmware. browse the link, select OS, download the firmware...
link: http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3690651&lang=en&lang=en&cc=us&cc=us
Dec 24, 2014 | HP Office Equipment & Supplies
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
What kind of error is 49.0665
This is a firmware error, that may be caused by corrupt printjobs or network issues. Try to see if you can narrow down the problem to a specific application and also check the URL below for any firmware updates. The problem can also be caused by faulty firmware dimms, memory dimms, or a faulty formatter board, but the message normally persist when this is the case.
Go to htpp://www.hp.com/
support/LJ4200 or htpp://
www.hp.com/support/
LJ4300. Select Download
Drivers and Software. Check
for the latest firmware image
version at the bottom of the
page. If this firmware image
is newer than the one
installed on your printer and
your printer can receive a
firmware update, download
the newer firmware upgrade.
Not all HP LaseJet 4200/
4300 printers can receive
firmware upgrades.
Jan 14, 2013 | HP LaserJet 2420 Printer
49.4C2D ERROR HP P 3005
49 errors are normally Firmware errors. 1st try to print from a different application. If you still get the error go out www.hp.com/support After answering the question go to the drivers and look for the firmware downloads. Download and install the latest firmware. Make sure that you follow the directions. And don't touch the printer until it reboots.
Aug 19, 2011 | HP LaserJet P3005 Printer
Download file now RFU LOAD ERROR
Upgrading Printer Firmware
WILL SOLVE YOUR ISSUE
HP Jetdirect firmware images have an extension of *.dld while the printer
firmware images have an .rfu extension.Once imported into the repository, the files physically exist under the following location on the HP Web Jetadmin server:
C:\Documents and Settings\NetworkService\Local Settings\ApplicationData\Hewlett-Packard\HP Web Jetadmin\WjaService\config\FirmwareUpgrade
check the document from the hp
Jan 05, 2010 | HP Office Equipment & Supplies
The HP DesignJet T1100ps printer has a 79:04 error code. What kind of error is this and how can I solve this problem? please, help ! !
hp will never tell you but this error is a kind of a catch all error basically the service manual says to reload the firmware. check the file you are sending. i have seen a bad file cause this error. hope this helps.
Jun 09, 2009 | HP Designjet T1100ps Printer
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
Support
49.XXXX
PRINTER ERROR
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error
1 Press CANCEL JOB to clear the print job
from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4200_software,
www.hp.com/go/lj4250_software,
www.hp.com/go/lj4300_software, or
www.hp.com/go/lj4350_software.
Select Download Drivers and
Software
. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade. Not all
HP LaserJet 4200/4300 printers can
receive firmware upgrades.
4 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file.
hope this helps you
pdouglasss
Dec 10, 2008 | HP LaserJet 2420dn Printer
BIJ 2800 unable to print as error "-00D4-c3f9 LIB MICCI.DL212" error appears
HP All-in-One Products - Performing a Partial Reset of the All-in-One Introduction There are times when a partial reset may be required to restore the all-in-one to proper operation. A partial reset does the following:
  • Reset the user settings to the factory defaults.
  • Reset the language and country/region settings on some models.
Performing a partial reset Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
      NOTE: If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  3. Press and hold the button combination for your all-in-one.
  4. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
Product family/model
Button press
HP PSC 2500 series
Press and hold # and 3 while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+ ) instead of # .
Apr 21, 2008 | HP PSC 2355 All-In-One InkJet Printer
200 people viewed this question
k24674
jasbo
jasbo
