Question about Proform 490 C Treadmill
Using a friends for the first time. After powering up, it ask for a key. Where will I find the key and its insert area?
    President:
  • 1,102 Answers
The "key" is inserted in the front of the panel and attaches to your wrist or clothing. It is a safety device that will shut off the treadmill of you fall down or off. If it ins't with the machine then you might be able to obtain a repacement from the manufacurer on-line.
Posted on Dec 29, 2010
Cannot open my phone after too many attempts entering wrong pattern,and it asked me my google account with crrect password but it doesnt work
1. The device must be powered OFF to hard reset.
Note: If the device is not responsive and does not turn off, remove the battery and re-insert it.
2. Press and hold the Home button and the Power button at the same time.
3. Keep holding Home and Power together for at least 25 seconds, even if the "Startup" screen appears.
4. Release the keys when you see a black screen with a warning sign.
5. Slide the keyboard open.
6. As a shortcut, press ALT+W to factory reset the device. If this does not work, continue with the below steps.
7. Press ALT+L.
8. Press Alt+W for 'wipe data/factory reset'.
9. Press the Home + Back key.
Note: You can also remove the battery and re-insert it.
Thanks for using fixya
Oct 12, 2013 | HTC G1 Smartphone
Check system then press f1 key
Try this:
Instructions
    • 1
      Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
    • 2
      Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
    • 3 Hold down the "F12" key, at the same time hit the "Power" button to turn the system back on. You don't have to hold down the Power button, but keep holding the F12 key.
    • 4
      Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
    • 5
      Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
Aug 19, 2012 | Toshiba Satellite A60-S166 Notebook
How to format my kingston128gb on window xp
Plug it in the USB, wait to be detected - an icon will appear in the notification area, open My Computer, Right click on it - it's the removable media entry, select format, select NTFS.
Sep 26, 2010 | Computers & Internet
Locked my keys in 2004 BMW suv.how can I open it?Thank you.
get a long screwdriver or crowbar, a blanket or thick towel,and bend the top of the door out as far as you need to get a wire coathanger in to retrieve keys.if you stand at the door and insert bar at about 40 degrees toward you and ask a friend to use the wire it is simple a matter of using the towel to stop paint damage.hope not to see you doing this in a parking lot........
Mar 20, 2010 | 2004 BMW 5 Series
Is there a way that I can reprogram a key fob from a 2003 Nissan Altima so that it works on another 2003 Nissan Altima?
yes u can and here is the procedure.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Jun 12, 2009 | 2003 Nissan Altima
Ea ssports cricket 07
dear friend .
you need to insert the cd for cricket 2007.
(it may be two cd pack)
insert the cd1 then autoplay starts .
and starts installing if it does not start automatically.
double-click on your cd/dvd drive.
after it starts it asks for key which u can get from
crack folder and right click on rid07 aand run as .
it generates the key which then can be used for the installation.
after that it asks for cd2 insert it and finish installing .
for playing u need to copy all files form crack folder.and paste them in your EAgames/cricket07 and replace existing file.them u can play the game.
thanks for reading the solution.
Mar 27, 2009 | EA Sports Cricket 07 for Windows
I Forget the BIOS setup password
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
Feb 18, 2009 | HP Compaq nx8220 Notebook
Rear hatch wont open
Spray WD-40 or similar lube in key slot, using red tube from can & insert it as far in the key slot as you can, and spray it often & lots, it may take quite a few times, or it may not release at all, but keep working the key in & out and try to turn as well as keep trying your power lock & remote. Get as much spray as you can up inside the handle area too especially at both ends. It's a hit & miss but you may get lucky. If you do get it open, you need to remove the inside panel & get to all the linkages, especially pivot points & spray them down good to unseize them, then after, coat them well with white lithium grease.
Jan 07, 2009 | 1999 Plymouth Grand Voyager
Keyboard problem
Sounds like a stuck key, you'll have to tap each key with the laptop off power until you can guess which may be sticking. A can of air used on the keys will also help to dislodge anything that may be helping a key stay half pressed.
When you start up and you get this series of tones anyway after, press the Escape key a few times and see if that doesn't resolve this issue.
Some keyboards need to be replaced if a stuck key is due to a mechanical malfunction. In this case, you will want a qualified technician to do this work for you, and be certain they have experience in laptop assembly. Don't rely on a neighbor or friend who wants to try for you. A good expensive piece of equipment can be rendered useless.
Ask any further questions by using the Comment Text Area below this and I'll get an email you have a question or more information for me to work with.
Regards,
Worldvet
Nov 03, 2008 | IBM E 74M 17" CRT Monitor
Proform 490 C Treadmill Logo
65 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
