Question about Refrigerators
I purchased a Model# TFX25PRYD GE Profile side by side refrigerator / freezer in 1996. The refrigerator is running but the inside is why too warm. The freezer side is staying at 12 degrees and the refrigerator side is staying around 62 degrees. No air flow is felt on the refrigerator side but some air flow is felt on the freezer side. What could be the problem and how can it be fixed? Would it be best to just purchase a new one?
SOURCE: GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Posted on Aug 14, 2008
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
  • 958 Answers
SOURCE: Dual zone Danby Wine Refrigerator.
adjust the thermostat all the way to the coolest position and observe it for 24 hours
if it is still 62-64 degrees, then something is wrong. observe what is happening with the unit. is the compressor running, is there a fan which could not be running? or anything that you think is not right.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
  • 33 Answers
SOURCE: Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Posted on Nov 29, 2008
  • 71 Answers
SOURCE: Hello, I have a GE
more info ie no crushed , no ice, no water?
Posted on Dec 24, 2008
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
Freezer n refrigerator is warm at 78 degrees
If the compressor is running it either has broken valves or the refrigerant has leaked out. Without knowing more than the information you've provided I would start with the basics. Does the fridge have power? Can you hear both the condenser and evaporator fans running? Have you checked the coils under the fridge to see if they are clean?
Jun 21, 2010 | GE Profile Arctica Stainless Steel Top...
I have an older GE Profile side by side not defrosting, have continuity in element when warmed thermostat kicks off and I have replaced the timer, still not defrosting. Model #THP21PBSMWW S/N SL238841
Need to check and see if the element is heating up when it goes into defrost. If the thermostat is bad it will not go into defrost. I purchased a new heating element for my GE and it came with the element and thermostat together. Also make sure the fan is running in the freezer this moves the heat through the coil as well as the cold temp when in freeze mode.
Nov 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
TFX25PR TFT25 PR GE Profile 25.2 cu ft no frost Serial GS248611 Model TFX25PRYD WW Water collecting and freesing in bottom of freezer side and running out the front, Drain tube at back is NOT...
Here are som links that will be helpful. I believe ice is blocking the defros condensate dran behind the freezer back wall of the freezer compartment.
Here are some helpful links.
http://appliancejunk.com/forums/index.php?topic=22.0 and http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/ Pour a warm solution down the drain with Clorox and I think that will help too. Hope this helps. Thanks, Sea Breeze
Jul 28, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge not cooling or freezing
Work on the fridge problem first and the freezer may be fixed by that.
1/Thermostats lose sensitivity over time. The thermostat or sensor may be defective.
or
2/ You have lost some of your refrigerant and it is undercharged. It does evaporate very slowly but a pinhole would lose it in minutes.
Do not continue to run it or your compressor may overheat and fail. The sides of the fridge are probably quite warm from this happening already.
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
