Question about Vacuums
Rowenta Effective DX 1700 model---won't spray water?!
    Problem Solver:
  • 3 Answers
Mine was getting slow to steam, downloaded a manual (could only find model #1900, but close enough), and found out how to clean- fill with water, heat to the highest temp, hold over the sink horizontally and hold the steam lever over to the "self clean" position for one minute. That's supposed to purge the system of junk. Manual site: http://dl.owneriq.net/2/28c59722-2a7e-45ae-b333-c20240d7e9f5.pdf It's a free download.
Posted on Feb 13, 2011
Hi , I am looking for a Vacuum bag and filter for my Rowenta Vacuum cleaner Model number:RO1767R1 Type: VC20PE3 Ref. number : RO1767R1/4QO-3312R.
Here's one source for the ZR0039 01 paper bag and microfilter for the RO1767R1 compact canister vacuum: https://www.alza.co.uk/rowenta-zr003901-d308208.htm?catid=18850976 . This is a 6 pack of the bags. This vendor also has the Wonder Bag for this model: https://www.alza.co.uk/rowenta-compact-wb305140-wonderbag-d308211.htm?catid=18850976 . I can't find a source for the HEPA filter version (ZR0041 01).
This store has other locations. You can also find the vacuum bags here: https://www.alzashop.com/rowenta-zr003901-d308208.htm?catid=18850976 .
I hope this helps.
Jun 03, 2016 | Rowenta Vacuums
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Sep 20, 2012 | Bissell 1716 SpotLifter PowerBrush
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Bissel cleaner won't stop spraying water
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
May 08, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
I need a customer service manuel. i lost the one that came with the iron when i bought it. it is probably called an instruction book.the model # is 273 .i hope you can hep me get one. thank you for any...
Can't quite track that down by the model number you show, but if you go to this URL:
http://www.rowentausa.com/rowenta/frame.aspx
there is information on an Effective iron that looks pretty close. There are downloadable files in the lower left hand corner. You might have better luck than I did tracking the model number you have at this site as well.
If this solution was helpful to you, I would appreciate a Thumbs Up from you.
Be well, Paul
Oct 05, 2010 | Rowenta Vacuums
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Vacuums Logo
130 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
