Question about Philips GoGear HDD6330 MP3 Player
Philips gogear 2gb player
Was working fine now it wont switch off and wont connect to computer why?
  • jbousier Jul 14, 2008
    can't sync music.
  • Anonymous Jul 28, 2008
    ok i have the 2gb mp3 player too and i uploaded some music on it and when i disconnected it form the computer it wouldn't turn on anymore
  • 8,596 Answers
All of you are having different issues
1.Reset
2.Run the repair in device manager
3.Run recovery mode: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Aug 07, 2008
My philips gogear vibe 8gb is brand new. I charged it and put on music and it was fine for an hour. But now it freezes on the 99% updated screen. I reseted it and i can still usb connect it but after it...
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, you can format the player. Provided its recognized by the computer. Contents may be removed by using this function. So make sure to back up your contents. Here is how to do this:
Connect your GoGear player to your PC. On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format". Disconnect it once the format is complete.
If that doesn't work, you can repair the player. To repair it you must have the software that came with the player or you can download it from the Philips suppot site. WWW.philips.com/support/. Players that start with SA1xxxx uses Device manager and the Players that start with SA2xxx uses Philips Songbird.
Here is how to Repair your GoGear MP3 player using Device Manager:
Launch Device Manager and click the Tool menu and select "Repair my Philips GoGear", then follow the instructions to perform the repair process.
Here is how to Repair your GoGear MP3 player using Philips Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair my Philips GoGear" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
*Contents may be removed by using repair and format functions. So make sure to back up your contents.
Hope this helps.
Cheers..
Feb 27, 2011 | Philips GoGear ViBE Digital Media Player
Hi team,i am facing problem with philips go gear 2GB player, Problem is :when ever i switch it on,"please connect to Pc and use device manager to repair" please help me in this scenario,explain...
I'm not a team member, but
1. Select your GoGear 2GB player from this list:
http://www.search.philips.com/search/search?q=GoGear+2GB&s=all&l=global&h=all&o=
2. When not having the program Philips Device Manager installed on your computer yet: Look under Software and Drivers, select the Device/Firmware Manager for your player.
2.1 Run the execute file Device Manager for installing the Device Manager toolbox.
3. Run Philips Device Manager:
  1. Having launched Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA2XXX -> Philips SA2XXX Device Manager on your PC
  2. Connect your player to the PC
  3. Device Manager should acknowledges your player and automatically goes into recovery mode.
  4. Follow the instruction of the Device Manager.
  5. After the player has been repaired, remove it from your PC and re-start.
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Philips Audio Players & Recorders
It wont work
goto philips.com then under support and elctronics find your model and download the repair utility and run it on your mp3 player try that first you can also put it into recovery mode by holding the volume up button while you connect it to the pc
Sep 27, 2009 | Philips GoGear SA3125/37 MP3 Player
2GB go gear philips wont upload videos
first off get the arcsoft media converter 3, then drag and drop the videos you want to get on your mp3 player into the program, after it converts it it loads them onto your mp3 player as long as its connected, this program will also allow you to download youtube videos and put them on your mp3 player too this should help a bit
Mar 24, 2009 | Philips GoGear HDD075/17 MP3 Player
Philips gogears 2gb SA6025/02
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 16, 2009 | Philips GOGEAR SA6045 MP3 Player
Wont turn on.
you have to return thems there working fine i got one me too !!!
Dec 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
Please connect to pc
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 29, 2007 | Philips GoGear HDD1850 MP3 Player
Philips go gear 6gb not connected.
-Tha Mp3 Doctor
Nov 25, 2007 | Philips GoGear HDD6330 MP3 Player
Philips 1630/17 6gb mp3 player
-Tha Mp3 Doctor
Oct 09, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
137 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
