Question about Water Heaters
We have recently begun using a seldom used shower in our home. The water heater is electric (in the rest of the house, water is gas-heated) and the shower has not been used in nearly a year. We all have extremely dry and straw-like hair after just one shower! No problem with the water in the other showers in the house but an immediate change after using this one. You can feel some kind of residue on your hands when you're done. What could it be?
I'm not sure what the problem is.
At least nobody is sick.
1) Water heaters should be flushed periodically, especially when region has water issues such as hard water.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
2) When finished flushing water heater, remove cold water line and pour in 2-4 pints hydrogen peroxide and then fill tank, let sit for 20 minutes, and then drain tank. Hydrogen peroxide will kill bacteria. Trace amount is not harmful to humans since it is also used for cuts and oral sores.
3) Turn thermostat up to 140 for a time to kill off any bacteria.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
4) If water also has odor, or if problem persists, the anode rod is suspect and should be replaced.
http://waterheatertimer.org/Replace-anode-rod.html
5) Post your question on professional plumbers forum at the Tank
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Dec 29, 2010
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Jun 13, 2012 | Rheem Water Heaters
Is the Whirlpool Electric Water Heater Model # EE3J50RD045V energy star rated
You want to know if this heater has Energy Star label.
I don't know.
Call Whirlpool 1-877-817-6750
Energy Star is a label that means nothing to you.
Manufacturers use energy-star label to promote a product as a money-saver.
They can put an Energy Star label on a giant 10,000 square foot house, and you know that cannot be the truth that a large house saves energy vrs a smaller house.
Energy factor, (energy factor/ not energy star) on the other hand, is a comparison measure how efficient the water heater uses energy to heat a gallon of water, when water heater is absolutely new.
EE3J50RD045V has energy factor of .59, which is completely typical and ordinary for electric water heaters.
The EE3j 50 gallon is an ordinary electric water heater, with ordinary average .59 energy factor rating, so electricity to operate this water heater is same as any other typical 50 gallon electric water heater: it will cost $35-45 a month depending on incoming water temperature, hot water use, thermostatic setting, electricity pricing, and whether you operate heater at peak pricing, etc.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/How-much-does-it-cost-to-run-water-heater.html
The most important measure of water heater cost does not have anything to do with Energy-star or energy-factor.
The most important measure is total cost of owning and operating the water heater.
So if you spend $100 more to purchase electric water heater with slightly higher energy factor, then it will not pay you back. The difference will be $2 to $4 per year.
All costs are energy.
The total cost of operating water heater includes purchase price, installation cost, cost of repairs, cost of parts, whether you can fix it yourself, expected life of water heater, and replacement cost.
Every water heater has expected lifespan, and will not have resale value except current price of scrap.
Electric water heaters cost more to operate per month than same-size gas water heater.
Gas water heater might cost less over the life of water heater, but gas water heaters are increasingly expensive to repair, and increasingly more complicated, and cost more up-front to buy.
Electric water heaters cost less to buy, are easy to install yourself, are fully repairable by homeowner using generic off-the-shelf parts, and can be made to last many years by keeping tank clean and replacing anode rod every 2 years.
You can make ordinary 6-year electric water heater from box store last almost indefinitely.
Avoid electric water water heater that has electronic controls.
Sep 20, 2011 | Water Heaters
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
What is the minimum GPM's for a Rheem tanklers water heater to work? I can only run the shower by itself. Also can I install an outdoor tankless Rheem in an area where it gets down to -10 degrees F ?...
Rheem makes a number of tankless models
http://www.rheem.com/products/tankless_water_heaters/
They make a tankless 95 outdoor series
http://www.rheem.com/product.aspx?id=EBA80FAA-3C0F-411D-AF83-82061C28ED1B
The 95 outdoor series spec sheet says .4 GPM minimum activation and .26 GPM flow to keep burner activated. The colder the incoming water, fewer users can take a shower at once.
http://globalimageserver.com/fetchDocument.aspx?id=ea5f0816-dfd4-4bcf-a605-79945619f5bb
The .4 GPM and .26GPM numbers are fairly typical for tankless units.
These numbers are good when the unit is new.
After a few years the number may be different because the tankless is a high-tech machine with sensors that are susceptible to particulate in the water, and susceptible to perfect-functioning of other parts in the machine.
The outdoor series spec sheet says the tankless is good to minus 30 F.
But remember that's when the unit is new.
Outdoor tankless water heaters have an electric heater that keeps water pipes inside the unit from freezing, as long as electricity is ON.
If electricity goes off, the house stays warm inside for several hours.
But a steel box located outside would get cold immediately without electric heat.
The electric heater adds standby cost to operational expense.
The tankless has a heater, but you still have to protect the incoming and outgoing pipes.
If your incoming water is very cold, the tankless heater may not be able raise the temperature fast enough to give two showers -or- even 1 shower depending on age and efficiency and capacity.
You can add a tempering tank located in naturally warm area that passively pre-heats incoming water before it enters the tankless burner.
It might be best to locate tankless inside the house >> and use direct vent through the wall for both incoming air supply and outgoing vent gas.
If incoming air is taken directly from the living space, then tankless will draw air into the house through cracks and around doors.
A lack of sufficient air, or poor air quality can cause the burner to shut down.
When buying a tankless, read the spec sheets and really ask questions about everything you don't understand.
Oct 24, 2010 | Rheem RTG-53PVN Indoor Natural Gas...
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
On-Demand Water Heater
An on-demand, or tankless, water heater is a system for heating water as it passes through the pipes, usually very near the point of use. Traditional tank water heaters bring the water to approximately 140 degrees Fahrenheit (60 C), in order to ensure the water supply lasts long after the heater turns off. Since this is obviously far too hot to be pumped out of a shower of faucet, cold water is added to the mix in the pipes. Coupled with the loss of thermal energy over time, the average tank heater has an efficiency of approximately 80%. On-demand water heaters have a number of advantages over their tank-using counterparts. While tanks often degrade over time and begin leaking, the apparatus used in an on-demand water heater is much less susceptible to the burdens of age, and will often outlive the house they're installed in. The amount of energy used is a fraction of that used in a tank water heater, due to increased efficiency and a much smaller window during which a heating source is in use. While tank hot water heaters can, and often do, run out of hot water after a number of showers, on-demand heaters provide a never-ending supply of hot water, ensuring that warm water is always available when needed. A tankless water heater can cost between $500 and $1500, and they most commonly use either electric or natural gas energy to heat the water. Most mid-sized households report an energy savings of approximately 25-45% for a gas or propane heater, and up to 50% with an electric heater, over using traditional tank heaters. Water is usually set to a maximum temperature of 120 degrees Fahrenheit (49 C), though many heaters allow for custom setting of the maximum temperature via remote control. Outflow rates range from 8-14 gallons (30-53 litres) per minute. Installation for most tankless water heaters is incredibly easy, involving simple plumbing. In the case of electric heaters, all that is required for a fuel source is to plug the heater into an outlet and begin heating your water. Some modern on-demand water heaters can incorporate a solar preheating system. This system uses a traditional solar heating system and tank to bring the water nearer to the desired temperature, saving substantial energy use in the final on-demand heating. A solar preheating system costs between $500 and $800.
Aug 27, 2008 | Stiebel Eltron CK20E Electric Tankless...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
