Question about Maytag Dishwashers
Can not find model number of my Maytag quiet series 100 dishwasher. It has a defective control board that has a bank of burnt resistors. Please help
SOURCE: Maytag Dishwasher Latch Sticks
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
Posted on Sep 12, 2007
SOURCE: Maytag dishwasher legacy 300 quiet series
FYI... I followed Miss Midget's steps... and there it was... a piece of plastic... actually one of the end caps from the rack. Poor design if you ask me. So for all you "grinders" out there, it's an easy fix... just need the appropriate star screwdriver. It went back together easier than it did taking it apart. Thanks.
Posted on Nov 28, 2007
SOURCE: Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Posted on Apr 06, 2009
tomsat69
  • 214 Answers
SOURCE: My Maytag dishwasher Quiet series 100 gets no water
I would cheak your float switch witch is located on the bottom of inner dishwasher move it up and down may be stuck.then try.If that will not work you may have a bad micro door switch.Good luck:)
Posted on May 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
Maytag Quiet series broken?
Check the door switch.
May 03, 2013 | Dishwashers
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
Maytag MDB7100AWB dishwasher board burnt resister
first of all they wont give you any specs on circuit boards for most appliances,they just want you to replace the board besides that,if a resistor burnt its because there was a heavy current draw on another component that is supplied by this resistor and you would need to locate this defective part such as a motor/solenoid/heater or the new resistor will end up in the same manner,the 2 oozing parts are probably capacitors leaking their die-electric compound from heat and age so they are in need of replacement too,you might go online and ask somebody with a board like yours for the part values,but still you need to find the main problem for the problem on the board first
Aug 12, 2012 | Maytag MDB7100AWB Dishwasher
Spray in control panel=lost power to Maytag Quiet Series 100
Have you checked the breaker to the unit? if not make sure you are getting power from the breaker to the dishwasher, if you are then check the wiring where it goes into the dishwasher to make sure you have 110 volts to the unit. if this does not fix it, i think it will leave me a msg and i will tell you more things to check, im not sure but there also may be a reset button on this unit
Feb 18, 2010 | Dishwashers
Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Oct 12, 2009 | Dishwashers
No power maytag quiet series mdb7600awq
To my knowledge, there are no fuses in a Maytag MDB7600AWQ. Should you be interested, you can reference the electrical diagram here. Exploded diagrams and parts placement are here. Based on these probable causes of no power would be:
  • no supply from the outlet, circuit breakers have tripped;
  • any of the two (2) door switch is faulty/open;
  • defective controller board;
  • defective AC cord.
May I ask, have you tried resetting the circuit breakers?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag dishwasher won't drain..
Please find attached DRAWING This will give you an idea how to tackle this
Jun 24, 2008 | Maytag Dishwashers
Dishwashers Logo
163 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
