I'm having a Convergence code come up. I have replaced the IC's and the 2.2 resistors. The TV comes on for a second with picture and shuts of again. Before I changed the IC's and resistors, The TV would come on and stay on for a little bit and then it would shut off and give a Convergence code. Then I could unplug it and plug it back in and it would do the same thing. Also, I had my laptop hooked up to it and if I had a movie playing through Windows Media Player or on Netflix, it would stay on. But the moment that cable or anything else from the internet came on, it would shut off. Now it will only come on for a second or two and then shut off with the Convergence Code (3 blinks).
  • 6 more comments
  • Charles Duncan Dec 29, 2010
    Is that for a rear projection TV? This was my first post and I posted in the wrong area.
    This is for a Panasonic PT-53wx53g Rear Projection TV.
    This is a Panasonic PT-53wx53g HDTV. I've already replaced the IC's and 2.2 resistors and it is coming on and then cutting off after a second or two. I've also tried the unplugging it for 40 minutes and that didn't work either.
  • Charles Duncan Dec 30, 2010
    It's a Panasonic PT-53wx53g HDTV
    Yes. They all appear to be functional and within tolerance.
    Yes. I applied an appropriate coating of thermal grease.
    Before I did the convergence repair, I could turn the TV on and it would play for a few minutes and then shut off. But when I played Divx movies from my laptop or a laptop movie it would continue to play well. But as soon as I played anything else, whether it was cable, xbox or DVD, it would shut off and give the convergence code.
    Can you e-mail it to me?
    chuck-duncan@live.com
  • 4,889 Answers
3 blinks is not a convergence error. On most Mitsubishi sets I have seen this is a short protect error. Can you please get me the model number of the tv so that I can tell you the location of the shorted component?
Sai.
Posted on Dec 30, 2010
  • 2 more comments
  • eagle338
    eagle338 Dec 30, 2010
    Ok. In that case it is a convergence error. It is always recommended to test all the resistors in the circuit correspond to the two ICs. I see about 12 of them. Did you test them all?
  • eagle338
    What about thermal grease? These ICs are very heat sensitive and should not be replaced without applying thermal grease on them first.
  • eagle338
    Ok. That calls for more comprehensive testing. Do you have the service manual, or should I give you the one I have?
  • eagle338
    Mail sent with the service manual as the attachment. I have also given instructions on browsing through the service manual.
    Genius:
  • 1,126 Answers
Try leaving your TV unplugged for 40 MIN.,that will reset the processors back to normal., if that don't work, then change the electrolytics on the convergence board , they go bad too.
Posted on Dec 29, 2010
  • Veril Gillette
    Veril Gillette Dec 29, 2010
  • Veril Gillette
Mitsubishi ws65713 picture goes out
I know these sets well, you lose brightness but still have sound?
If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 02, 2012 | Mitsubishi Televison & Video
The tv will come on for a split second then click and cut off its a mitsubusi projection ws-55809
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SD TECH
May 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: etower.766@netzero.net
I do this here for free so if this has helped you give me a vote here.
Aug 18, 2009 | Televison & Video
I was watching it and it just shut off when i turn it on 3 seconds later it shuts off again
this set has a self diagnostic feature:
If this has been helpful I would appreciate a vote from you here; if you need direct help:
Aug 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV turned off and now the power light blinks three times
Very common problem. 3 blinks means the convergence circuit has failed . Heres a link to the repair kit for your model which contains both convergence IC and the feed resistors and the kit has step by step instructions with pictures so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I need to identify the parameters (rating) of a resistor for a Panasonic PT53WX53G projector big screen tv. It got hot so I can not see the color codes on it. This resistor glows red when TV is turned...
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Magnavox 55'' Projection - Sides come in and out
sounds like Convergence issue.... I have some pictures of the bowing picture TV on the link below...
I'll post you my general message which is for a similar Philips Magnavox 51 inch TV, you'll need to check the manual verify the correct IC convergence chips and resistors, the manual link is below as well... usally the IC's are STK392-120's or 150's and the resistors are 6.8 ohm 12 of then...
anyway read the general post below it will get you headed in the right direction.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
SAMSUNG HCM4215W Rear Projection HDTV shuts down
Low ohm resistors are open or poor solder connections on the bottom of a convergence IC.
You need to look at resistors in good light with magnifying glass. Bad ones may show as discolored or burnt.
The repair needs someone that has the schematic for the convergence cct, and can replace the burnt resistors or replace the whole convergence board.
http://calgaryconvergencerepair.weebly.com/index.html
If you are near Calgary, call me, if not, find someone that has done it before, preferably many times.
easyab
Aug 12, 2008 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
