Question about Dishwashers
I have a bosch dishwasher model she46c. the float stuck and the pump ran and almost burned out smelled burnt. got washer to restart everything works but pump is noisy. replaced pump but it is still noisy. What do I need to check? nothing is stuck in pump. thanks ron
SOURCE: Bosch SHU9925UC Dishwasher Stuck in Initial Drain Cycle
OK Bosch Dw fans.........here is the fix if your SHX dishwasher is stuck on the drain cycle. This may save you a couple hundred bucks.......so listen up. There is a tendency for the very small float switch to STICK in the ON position, which will cause the drain motor to continuously run......and DISallow any other function to work. DISCONNECT POWER. Did I mention to disconnect power? Take off the front base cover....2 torx screws. Remove the other 2 torx screws in the metal clips that fasten the top of the DW to the underside of your countertop. NOW...carefull slide your DW out. You may have to disconnect your water and elec supply if you do not have enough slack to pull it out. Once the DW is out of the cabinet, remove the shiny metal cover on the LEFT side by removing a single torx screw. You will now see a small plastic assembly with a red plastic piece that moves up and down as it rides on a small red styrofoam float. This up and down movement engages a small white plastic switch visible with 3 wires coming out of it. You can carefully UNSNAP this switch out of its mount, and pull the 3 wire plug off of it. THere is a small square blue plastic tab that is supposed to easily slide in and out of the switch. If it is stuck IN, you can sometimes tap the switch and the blue tab will pop out, which is what it is supposed to do without tapping it. You can carefully with a knife blade separate the case on this switch and note the way it comes apart. Clean out any micro debris out of the small channels that the blue tab ride up and down in. Then set it in the channel while holding up the small switch tab that rides on it and see if it slides up and down without sticking! I like to take a piece of wax paper and rub in on the channel and blue tap to provide some lube for the switch to slide easily on. Now, put the switch back on and manually move the red plastic assembly up and down while you are watching the blue tab. The tab should ride up and down with the red assy. If not, buy a new switch. Google the # on the switch and order one. If the tab slides up and down, put things together in reverse order and give it a try. Hope it works for you. This should take you an hour give or take. Take the $200 you just saved and have a night out on me. ........so even though these German Appliances have a good name because of past reliability, the american tendency to value engineer them with plastic parts to reduce costs and increase profit.........just cost you an hour of your time. Will we ever learn.? ......if it ain't broke, value engineer it until it only lasts through the warranty period so you can then collect service and parts blood money from your fellow american.
Posted on Jan 11, 2009
RepairClinic
  • 32 Answers
SOURCE: Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 11, 2009
  • 86 Answers
SOURCE: where is the float on bosch silver edition?
Hi, This model could well have two systems that will let it fill. One will be on the left hand side as you look at the dishwasher which will require you to remove the side panel. Start with this first as if it is the later version then it will be in the bottom of the dishwasher which will require you to remove the side panels to get to it. The switch in the first method will be a small micro swith and the other will be a large pressure switch located in the bottom. I would think it will be the first method.
Look at it and let me know how you get on.
Posted on Feb 27, 2009
lsteward68
  • 331 Answers
SOURCE: no water being allowed into dishwasher
you may have a bad water soleniod. there is also a mesh on the solenoid. go here to identify
if you have your model number and make you can go here to identify it www.techray1.com then click on the guru guy on the left. this will open another window. on the left you can select your model and unit and part. If this helps please rank me
Posted on Jun 22, 2009
jmgldsmth
  • 1889 Answers
SOURCE: Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Posted on Jul 01, 2009
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Smelled like burnt board
Just so you know. Bosch has a 5 year warranty on any printed circuit board (excluding labor) so you pay only for labor charges. They have a 2 year warranty (again excluding labor) on the entire dishwasher. I am leaving a copy of my owners manuals warranty information I hope this helps.
Extended Limited Warranty: Bosch also provides these additional
limited warranties:
• 2 Year Limited Warranty: Bosch will repair or replace
any component that proves to be defective in materials or
workmanship (excludes labor charges).
• 5 Year Limited Warranty on Electronics: Bosch will repair or
replace any Bosch microprocessor or printed circuit board if it
proves to be defective in materials or workmanship (excludes
labor charges).
• 5 Year Limited Warranty on Dish Racks: Bosch will replace the
upper or lower dish rack (excluding rack components), if the rack
proves defective in materials or workmanship (excludes labor
charges).
• Lifetime Warranty against Stainless Steel Rust Through:
Bosch will replace your dishwasher with the same model or
a current model that is substantially equivalent or better in
functionality, if the inner liner should rust through (excludes
labor charges). Bosch will replace the stainless steel door if the
door should rust through (excludes labor charges).
The foregoing timeline begins to run upon the date of purchase, and
shall not be stalled, tolled, extended, or suspended, for any reason
whatsoever.
Repair/Replace as Your Exclusive Remedy: During this warranty
Jan 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Smelled like burning plastic
Ron, is this a dishwasher or clothes washer? If a dishwasher, check the wire nuts in the junction box. If there isn't a melted wire nut from a loose connection. Then you have to pull the outer door panel, then you can pull the control panel assy. This will require a t20 torx bit.
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
reove screws holding on outer panel and unplug all the leads ( they are all coded so you cannot cross them ) open up plastic cover on module to reveal circuit boeard
Stuck on first step of cycle (water draining). shu3036uc.
this may be due to a leak which you are not aware of. there is a float switch in the base which if operates, turns on the drain pump and nothing else. to check, tilt the appliance backwards 45 deg and see if water comes out of the back. if so, you are faced with identifying the leak which is often the main pump
May 17, 2007 | Bosch 24 in. SHU30 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
