Question about Acer Aspire ONE AOA110-Aw Netbook
Sorry for the confusion I did not install all 3 os in one time. I tried all 3 seperately. At the moment I only have the Ubunto 10.10. on a clean HD 1 partition The acer is also upgraded to 1.5gb RAM and has 8.1 GB SSD HD. The bios is starting and gives the possibility to change the boot order F12 when i change that into my usd dvd drive Ubunto is installing the OS. At the end Ubuntu says installation competed and restart PC The PC reboots in normal mode SSD HD and furter nothing apears. HD power led is and stays on. I can wait untill tomorrow but nothing appears.
  • 3 Answers
SOURCE: Lost Acer eRecovery password on Acer Travelmate 2350
If you have access to the Windows XP CD you can delete both partitions during the build process and then create one new large partition. The screen where you would do this is the first place the build process stops after loading the drivers, etc. You will see a list of existing partitions. Highlight the first one and there will be a choice to delete the partition. You have to confirm the deletion. Then do the same thing with the second partition. At this point you can proceed with the build process allowing the build process to create a partition of the available space. Make sure that you have a copy of any drivers that are unique, especially NIC. You can typically download these from the vendor's web site.
Regards,
Warren
Posted on Jan 25, 2008
i bought a acer aspire 3six20 from my classmate but i forgot tto backup the erecovery.. when i instaler a new xp the logo in6b5df8b.jpg
Posted on Feb 19, 2008
jeicrash
  • 320 Answers
SOURCE: Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Posted on Dec 15, 2008
Acer has a BIOS upgrade to recognize memory over 1 gig. You can get it and the BIOS flasher (Winflash) at their website.
Posted on Dec 31, 2008
sodeep
  • 3267 Answers
SOURCE: cannot reinstall new os, seem my hard drive is not detected by os
I hope its not Vista os, because if the driver is not in its database, it does not accept any new driver. Install XP first and run the Vista Upgrade adviser from microsoft to check whether your PC hardware will run Vista....sodeep
Posted on May 16, 2009
Core 2 Extreme QX6700 2.66GHz on ECS 945GCT-M3 (3.0) motherboard
Sorry, according to the manufacturer's website, the board does not support Quad core CPU's. Select the "CPU" tab on the following link. Also the Specifications tab confirms this. Your system uses DDR2 memory and is limited to 4Gb or slightly less if OS is 32bit. Also USB2 ports.
http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
If the rest of your components could support it, (Power Supply Hard drive(s), newer micro ATX MB's now use DDR3 much, much more than 4Gb RAM with 64bit OS's and USB3 ports that are ten times as fast as USB2. You would need to upgrade at least your memory and your CPU since neither would likely be usable in the newer MB's. Also, a 64bit OS such as Windows 7SP1 would need to be installed as your existing OS on your hard drive would not boot on the new hardware. Windows 10 appears to contain a lot of spyware which you must agree to accept before you can install it. It is in the Electronic User's Agreement of the Win 10 OS. No one usually reads these terms and conditions because you have no choice but to accept them if you want to continue with the installation, but some people have bothered to read it and have posted their findings. Just Google Windows 10 spyware.
Aug 14, 2015 | Computers & Internet
Tip
Install Ubunto OS in Windows XP
How to install Ubunto in Windows XP?
Just insert the Ubunto CD into CD/DVD ROM drive, then follow the installation process of Ubunto installer. Reboot the computer then you may now select which OS whether Windows XP or Ubunto.
Thanks!
on May 21, 2010 | Computers & Internet
How do i removing yahoo net safety from a mac
Download the App "AppCleaner.app"
Drag your Yahoo app to the "AppCleaner" icon
It will find all the associated files connected with the Yahoo item. Then just delete.
But.... Your machine looks like it might be in need of a full update?
Use this tool to see if your Mac can handle a Newer OS X.
Mactracker
This will give you all the tech info on your Mac
If Maverics is acceptable and you have say 2gb of RAM!
Then, Download the free Maverics OS X first.
Prepare an external USB Hard Drive (or Partition)
Try doing a full Clone Backup with CCC to the External HD
When finished Prove that the Clone is Bootable.
Use Option Key on Reboot. If OK
Use Drive Utility to Erase Internal HD ready for a clean install.
Then install a new clean OSX10.8 (Maverics) to get your machine almost up to the latest with a cleaned up pristine Mac HD.
Use Migration Assistant to return only the data files you want or just drag the "User" folder across by hand.
(Migration will bring back the Yahoo Software)
Mac Backup Software
OS Mavericks 10 9 Download
Sep 01, 2014 | Apple Leopard 10.5 Osx Mac Operating...
Takes a long time to boot up
clean your computer with CClean
Apr 04, 2010 | Compaq Armada E500 Notebook
Trying to boot from external dvd drive
u must either have one of the foll...to boot and install OS...also the seq in BIOS must be availabe and enabled
1 Floppy
2 CD Rom Drive - internal
3 CD Rim Drive - External connected thru USB
4 You can also try to connect a USB pen drive having the OS install program and try - I have not tried that so not sure if this option works...sorry
5 If u can open the machine then u can connect another internal HD(this can contain ur OS install files) to the cable (connector points in the flat cable) that connect your internal HD to the Motherboard.
if i can think of anything else i will post
all the best
Dec 31, 2009 | Dell PowerEdge 2600 Server
How do you flash the DVD drive with no OS installed? ( Gateway FX4710-UB003A) ?
you dont in most cases. Install Ubunto operating system, its free only takes minutes to install, it looks just like XP or VISTA. then run your program and flash it. Google "Ubunto" or linuz download.
Jun 05, 2009 | Gateway FX4710-UB003A Core 2 Quad Q9300...
Computer running slow
Hello.
Usually when a computer get to that point, is time to save your info, format and reinstall the OS, it will be like getting a new computer.
I know this can be a real headache, most the time you have no way to recover some softwares already installed because you don't have the installer and even worse maybe you don't have the Operating System Installer.
However, some responsible vendors make a backup of your system and store it in a separate partition at the moment you buy the PC, it can be named System Backup or something like that.
If you have that file in your hard drive or DVD you can :
Go to - Start - All programs - Accesories - System Tools - Backup and try that posibility.
You can try anything like antispys, antivirus etc but i have never found a way to make a computer in that conditions get fast again, only a clean install will give you that.
I'm sorry.
Good luck.
Jul 04, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Upgrading VAIO laptop HDD
get a lappy external caddy that is powered by usb place new harddrive in it. download a copy of hirens sorry dont have the link or use norton ghost ifyou have that boot lappy to os then load cd norton ghost or hirens.hirens has multiple software to disk copy simple and user friendlyso hirens is you best bet. after disk copy swap lappy drive around. send lappy model if you dont know how to install new harddrive i'll loook up to hirensfor you but you could try it was easy to find the last time i got it.
Apr 13, 2008 | Sony VAIO VGN-S460 Notebook
IBM NETVISTA P4 2.4G. no O.S.
If your old copy of win xp is not being used by any other computer then reformat the entire drive with xp. Also make sure that your drive is not divided into 2 or 3 sections. All updated will be available on the windows update site. The reason that I prefer tostart from scratch is Everything is new with no lingering Junk programs in the background. Need help email me at ddugard@cox.net
Apr 13, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
Problem
Hi, It is possible that your anti-virus quarantined suspected files but are required for booting up Windows. You can try: 1. Booting in Safe Mode to check things out; 2. Boot in last known good configuration; 3. Re-install Windows using the "repair" option. Experience has taught me that the safest was re-partitioning, re-formatting and do a complete fresh/clean/new install of the OS. Good luck and kind regards.
Sep 28, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Acer Aspire ONE AOA110-Aw Netbook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
