Question about Dewalt Clipped Head Framing Nailer
Just got a Dewalt D51825 Framing Nailer that takes 2" - 3 1/2", 30 - 34 degree paper collated clipped head nails. What is the best source for these nails, including recommended brand? Will it take galvanized nails? Will it take Ardox nails?
    President:
  • Dewalt Master
  • 1,388 Answers
Your nailer uses a very common and lowest price nail when using bright nails. Other varieties are expensive, stainless, twisted, galvanized, so if you are a big user not a problem. I on the other-hand do not use very many nails in a years time. A case of nails will last couple of years. A box of stainless or galvanized will be an expensive proposition. Because of the weight of case of nails, shipping is very expensive unless you find speicals. At www.toolbarn.com , you will get free shipping for orders of $200 (less than 70lbs). Best bet is to find local dealers, and right now because of the economy, special pricing. Look for deals on broken cases of nails. I usually find broken/open cases of nails at Lowes for half price. Buy what ever you come accross that is a good price because nails have a long shelf life if you can keep them dry. Good holiday
Posted on Dec 31, 2010
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
I need a owners manual for Dewalt D51825 nailer
Here is a site that has you manual. https://www.manualowl.com/p/Dewalt/D51825/Manual/182055
Jul 12, 2012 | Dewalt D51825 Heavy Duty 31 Degree Clipped...
My clipped framing nailer will shoot two 2 3/8 at the same time. what do I need to repair this gun?
I would look at the nail collation and nail angle first. If both OK for this tool, remove all the nails and air hose. Bounce the tip and see if the driver falls down on its own and if it does the o ring is worn and would need replaced. When inside the tool look for other wear items.
Mar 04, 2012 | Dewalt Clipped Head Framing Nailer
Air nailer bends nails
could be couple problems first make sure using the right type of nails I.E. collation and degree of angle. Next look for jammed nail in the nose area and then look at the nose condition for excessive wear and lastly look at the tip of the driver for wear and not being square so it drives the nail straight.
Sep 24, 2010 | Dewalt Round Head Framing Nailer D51845
Trouble finding 3 1/2 clipped head nails 34 degrees
You can use the same nails that are used for these nailers: Porter Cable FC 350A, Hitachi NR83AA2, Senco FramePro 701XP, 751XP ,Ridgid R350CHA, DeWalt D51822, D51823, and Paslode F-3505. Make sure you purchase the correct shank nail. Nail length should be 2"- 3 1/2" and the shank should be .113" - .131". I have purchased nails for my FC350 at Home Depot and they are relatively inexpensive. Though you have to buy a case of like 2000 or 4000. The brand of nail is Grip Rite that I purchased. Any questions please post.
Oct 06, 2009 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
For the Dewalt d51844 can you use PAPER or plastic collated nails
Yes you can generally interchange the two (paper vs plastic collated) as long as the nails meet the specifications (and collated angle) specified by your nail gun.
Please rate this solution on FixYa!
Thanks.
Apr 01, 2009 | Dewalt D51844 Framing Nailer
D51844 Won't Fire Nails
The Dewalt D51844 uses a full round head 20 degree nail. Sometimes the generic brand nails are not made exactly to the stated degree. They do this so their nails will work on a variety of nailers. Best to check the nails angle in relation to the angle of your nailer. Place a strip of nails on the outside of the rail. Align the heads of the nails to a convenient straight edge on the rail then check that the head and shaft of the first nail is aligned with the barrel. If the lower part of the nail projects out further than the head, then the driver will miss the head. If the head of the first nail appears close enough to barrell for the driver to hit it then place a new strip of nails into the mag and slide the pusher foward. Fire one nail, if success, remove the nails from the mag and check if the plastic holding the nails together is projecting in front of the first nail. Sometimes the plastic is not right, too stiff, and will not let the next nail align with the barrell. If the next nail appears ready and slides forward then the driver may not be going all the way up after shot. Check by inserting a metal rod into barrell and push driver up till it stops. If the driver is in the uppermost position, then most likely brand of nails. Use Dewalt nail. Good Luck
Jan 25, 2009 | Dewalt D51844 Framing Nailer
Dewalt Clipped Head Framing Nailer Logo
325 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
