GE Model WJRE5550H1WW When I press the start button I get lights but the water doesn't start filling. This has progressed from an occasional occurrence to frequent. Am considering replacing the board assembly but hate to spend the money if that doesn't fix the problem. been a good washer except for this.
  • 32 Answers
I am hoping you fixed this problem already but if not I here is what I found out last night. My washer was acting similar to what your describing. I hit the start and I get lights flashing between fill and wash. I found out the behind the control panel is a service paper. On this paper it will describe to you how to run diagnostic on the control panel to check for error codes and the functions for the washer(Pump,spin, hot water valve, cold water valve, slow agitate, fast agitate). When test the functions a second LED was lit indicating the pressure switch(also called water level switch) was showing a full load. Washer was empty! I then unpluged the washer and checked for continuity on the water level switch between the termials where the orange wire and the brown wire attach to. I was having sporadic continuity.(explains the flashing lights between fill and wash). If you have no continuity or sporadic like I did replace the switch. It is like $20 shipped on line. I hopes this helps. I spent I good 6 hours on the internet yesterday piecing info together on this because I couldn't find the same problem I was having.
Posted on Mar 07, 2011
  • 3 more comments
  • ramorristoo Mar 07, 2011
    Thanks, but I did already replace the water pressure switch (to no avail). It was inexpensive as you point out and a likely choice as the culprit. My model does not have a digital screen so there is not a diagnostic readout to show error codes and such. I next replaced the water inlet valve which again did not fix the problem. So I am still stuck with washing clothes when the machine feels it is ready, which is often enough to keep the family in clean clothes but not quite seldom enough to justify a new machine. Thanks for taking the time for your suggestion.
  • Dpiddy14 Mar 07, 2011
    The Indicator lights show the error codes. I have the same model. When you take the 3 screws out to get into the control panel there should be a folded paper on the back left hand side. It is the service sheet. It will detail you on how to diagnose/ operate the error code settings. It also has the error codes for the led indicator light on the motor control board. If you use a putty knife you can push in 2 clips and take the front panel off. Then on top the motor is a circuit board with a LED light the flashes. The service sheet explains the blinks. Also found out if you unplug the machine for 30 seconds or more then plug it back in and open/close the lid 5 or more times within like 10 seconds that it will reset the error codes.
    Thanks, dpiddy. Useful info and I will check out the service sheet along with your suggestions when I get a moment!
    I also forgot to mention when you take of the front cover of the washing machine there is a bundle of wire on the right hand side. About 3/4 of the way up the bundle should be wrapped with tape. The white wire with a red tracer has a built in fuse! This may be bad also. I would unplug the machine strip back insulation on both sides of the fuse and test for continuity. If you get nothing the fuse is blown and needs replaced. It is $10 from sears parts.
    Your welcome. Liked I said I just went through all this myself and I know how frustrating it can be. I just want to pass the knowledge along because this info seems to be hard to find on the internet.
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
I have a model WJRE5550H1WW washer that will fill agitate but will not pump out and spin
first check the lid switch, a lot of washers will agitate with the lid open but wont spin out. If its not that check your timer and then your water pump. Most likey it is the lid switch.
Feb 27, 2012 | GE WBSR3140DW Top Load Washer
GE washing machine model#WJRE5550H1WW machine will drain but wont spin
Hi.
Check motor, motor control unit, drain system (I know it drains) and pressure switch. Start checking from drain system and pressure switch. The pressure switch determines water level. The timer checks the output from pressure switch to decide that drain is complete and advance cycle to spin.
Check also the position of the drain hose. Ensure that the height is as specified by the manual or you get siphoning and drain does not end.
Here a page about drain/spin problem.
Start checking drain and pressure switch, then test the other parts.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | GE Washing Machines
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Top Poad WasherWJRE5550H1WW that intermittantly leaks
There seems to be an overflow drain from the top of the tub to the bottom (inside the cabinet). I don't know why this was designed to dump water onto your floor.
May 13, 2010 | GE Washing Machines
It started out not spinning. The lights would
kenmore portable washer will fill with water when button pulled out it just hums and occasionally tries to start.
Jan 30, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
How do you open GE washer model WJRE5550H1WW? When my washer adds water, some of the water drips down towards the bottom of the machine.
on the front panel under the lid/top piece are two clips use a screw driver to push trawards machine and it will bring front panel towards you and unhinge piece wala! all exposed
Oct 01, 2009 | GE Washing Machines
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Have a ge washer, filss then does not progress to
May be a bad water level switch.
Open the control panel, with a full tub of water bump the water level switch with your hand. If it starts to agitate, replace the water level switch.
Mar 20, 2009 | Maytag Performa PAV2200
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Washing Machines Logo
271 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
