Question about Bissell 1770 Quicksteamer II Upright Vacuum
My bissell lost its suction... - Bissell 1770 Quicksteamer II Upright Vacuum
My Bissell upright Pet vaccuum lost suction but the brush is still working...help
Posted on May 04, 2011
2 Suggested Answers
SOURCE: loss of suction bissell vacume
Under the red flap in the water resevoir, there is a small screen. Pop that screen out and clean it. It is probably blocked with hair. I took my entire machine apart trying to fix this problem and I finally saw that screen. I cleaned it out and my machine works like new now.
Posted on Mar 10, 2009
Lost sucion
Here's a quick link to troubleshooting. http://www.bissell.com/FAQDetail.aspx?id=1188&cid=ccsocial
If you continue to have problems, here's a link to locate one of our Authorized Service Centers.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 23, 2012 | Bissell 14251 Little Green ProHeat...
Hi, my Bissell 3920 has lost almost all of its suction. I checked the hoses and tubes but did not find any blockages. Filters are clean. Thanks.
Hi, Have you checked and made sure the floor plate is secure and tight without any gaps around the edges? If that's ok then check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself
Nov 27, 2011 | Bissell 3920 Bagless Upright Vacuum
My bissell proheat 2x has lost its suction from the floor but not from the tool.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction on either vac or upholstery attachment...does spray
check to see if the red lint filter in the clean dirty water tank is clean and free from fluff if this is glogged this will resticted the suction ,check to see if the tank is seated corretly
May 24, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuum Does Not Have any Suction
it could be clogged somewhere inside the hose. try unclogging it with a thin pole or rod.
Mar 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
http://bissell.com/images/schematics/1950.pdf
Jan 29, 2008 | Bissell Powersteamer 1694 Upright Vacuum
My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Dec 15, 2007 | Bissell 3522 PowerForce Bagged Upright...
Bissell 1770 Quicksteamer II Upright Vacuum Logo
306 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
