Question about Mtd 22" Yard Machine Push Mower
I have a 5 horse two stage yard machine snow blower. It is about 4 to 5 years old. It will start and idle as long as the choke is on. once the choke is turned down it dies immediately, even after being warmed up for a few minutes. When I engage the auger it also looses power and will die. I can put the wheels in motion just fine. Any ideas?
    Sergeant:
  • 223 Answers
It sounds like either the carburetor is gummed up or has water in it. Let's be sure gasoline flows well to the carburetor before doing anything else. Pull the fuel line off at the carb. and run some into a glass jar. It should pour out, not just a trickle. Look for water in the fuel, if there is any then let it settle before pouring the fuel back in, just don't put the water in. If fuel doesn't flow from the line well determine why- clogged filter, foreign matter in fuel tank, etc. Look and see if there is a screen in the fitting on the carburetor- these can plug and give you just the issues you're seeing.
If you have the B&S motor with the carb mounted right to the fuel tank just go to the next step.
Fill the tank most of the way with clean fuel and spray about a half can of Gumout aerosol carb. cleaner in the tank. The screw-top can of Gumout isn't the same, use the aerosol. Fire it up and let it run for half an hour, see if it's better.
If it doesn't straighten out with the Gumout then it's probably water- taking the air cleaner off will allow you to put your hand over the carburetor throat- open the throttle wide and pop your hand over the carb. so that you flood it mightily for a moment, then take your hand off and let it recover and run smooth. Repeat a couple of times and see how it runs now. This will pull the water from most carbs, if it doesn't seem to then you can try a little alcohol in the fuel. Alcohol will remove the water but it takes a long time, it's easier a lot of times to just open up the carb. and let the water out.
lp
Posted on Dec 29, 2010
    Genius:
  • 1,267 Answers
I hate to say this but it sounds as if your carb needs cleaning as the fuel flow is being restricted at the un-choked position. Before you have to take the carb apart, try this. Go to Walmart, or Northern Tools and buy a can of "SEAFOAM" which is a fuel additive that cleans carb jets and passages, and may over time unclog your jets. Other cleaners on the market work so if you can't find SEAFOAM, then use another. Siphon all of the old fuel out of your tank into a plastic jug, put fresh fuel into your tank.Pour twice the amount recommended in to your tank, and start the machine with the choke on and let it get the fuel mixture running into the carb. Run it as long as possible and when it dies out, let it sit for a full day and night. Try it again and repeat the running process.
The fuel that you use is 10% ethanol and alcohol is very hydroscopic and sucks in water and combines it with the gasoline. This water latches on to dirt and grime, and junk and eventually clogs the jets. If you let the gasoline with the ethanol sit in your tank unused for more than three months, it becomes jelly like. That is why it is a prudent measure to run all of the gasoline out of your machine before it sits for anytime longer than 3 months. Some wag said that the government mandate to add 10% ethanol to gasoline was just a full employment contract for engine repairmen. If you plan on leaving gasoline in small engines for a period of time you need to add some "Stabil" to it to prevent jelling of the gasoline.
Troy Bilt 3090 snowblower surges off choke, doesnt surge on choke, cleaned the carb, jets, float, drained tank, cleaned fuel filter, fresh gas, still surges. Could it be the governor or idle jet?l
you could try opening up the idle/mixture screw another turn to make the transmission from idle to throttle better
governors just open the throttle butterfly according to the spring tension setting from the throttle lever
Dec 16, 2016 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Snowblower troubleshooting
Either the gas is old (replace it with fresh gas) or the carburetor needs cleaning inside. Unless, of course, someone has tampered with your idle mix adjustment screw.
Feb 18, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
My snowblower will only stay on as long as I continue to push the primer. Once I stop it stalls. And the choke is closed.
The bolt that holds the carb bowl on either has an adjustment bolt or it does not. If it does not have this adjustment screw, there is a small hole in the midde of the bolt that needs to be cleaned. The hole is the jet for the carb. I usually use a wire from a price tag and then use carb cleaner with the straw to pressure clean it.
Jan 06, 2014 | Yard Machines 26" 208cc Two Stage Snow...
Yard machine snow blower
be sure to check in blower housing (the round part) that impeller isnt frozen at the bottom
can also take off belt guard (2bolts) and check to be sure belts are on correctly
Dec 18, 2013 | Yard Machines 28" Two-Stage Snowthrower
Not getting gas
The bulb usually doesn't feel that way, you're thinking of a small 2-cycle machine where the bulb will fill up with fuel and offer resistance when pushed. A primer on a snowblower is merely to get fuel flowing to the carb from the tank, whereas the bulb on 2-cycle items actually purges air from the fuel circuit. If you keep pressing the primer you should see fuel drip from the carb inlet. Btw, if you see where an air filter might be on other motors, a little metal cup looking thing, try removing the bolts and flipping it over so the fuel drips out easier and snow doesn't have the chance to fall into it if it were facing up. Once you see fuel dripping out, provided you ran it dry last season when you put the blower away and the carb isn't gummed up with varnish, it should start on full choke. Give it about 3-5 seconds and move it to half choke. Once it seems to want to run on its own, open the choke completely and you should be warmed up and ready to go. Also always remember to let engines idle a bit to cool down if you've been running them at high rpms.
Nov 11, 2013 | Mtd Yard Machines 24" Two Stage Snow...
On my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Dec 10, 2008 | Garden
Mtd 22" Yard Machine Push Mower Logo
157 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
