Question about Dehumidifiers
Model is FDL70S1 bought 6/14/09 ; had in continuous operation for almost a year till this summer when it stopped taking humidity out of the air. I recognized ice on the coils above the bucket. Ever since it won't take water out of the air. Can you help me in determining what is damaged or wrong and how much the repair would be? Thanks Armin
  • 43,501 Answers
Unfortunately the ice was a symptom of the refrigeration system having a leak and the charge being too low in the system. Since then the system has lost enough freon so that it no longers works...
given the low cost of these units, it will cost you more to have the leak found and repaired then it will cost to buy a new units...
Dispose of the unit properly and buy your self a new unit...
Wish I could give you better news... :-(
heatman101
Posted on Dec 30, 2010
Is it possible to buy a portable dehumidifier which will automatically restart and function after a temporary power outage? What do you ask for?
Hello William, thank you for your post!
I understand that you would like to have a dehumidifier that restarts after a power outage. I have reviewed the available models for Frigidaire and show that feature is not available. You may want to speak with additional manufacturers for that feature. I hope this information is helpful to you. -Matt
Mar 20, 2016 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Tip
Taking the Confusion Out of Using a Dehumidier
Many consumers are confused about setting the proper levels of humidity on dehumidifier units. And then think something is mechanically wrong with the unit. When in fact, over 70% of the time it operator error. That and a lack of proper routine maintenance are the problem.
The numbers on the LED screen represent the amount of humidity you want to maintain. Not the amount you want to remove. For example: If you set the level at 70%, which is rather high, more than likely the unit may start up momentarily and then shut OFF. That's because the setting is to high. Now, if you set it at 45%, the unit will turn ON and run until either the bucket is full and/or the humidity level has reached 45%.
Here's a good rule of thumb if you use your humidifier year round.
In the Winter you want to maintain a humidity level of 50 to 60%. The moister the air, the more comfortable it will feel. Plus, the humidity helps eliminate static electricity in the air.
Conversely, in the hot, humid Summer months, you want to keep the humidity level as low as possible (35% or less). Also, if you have ceiling fans, using them 24 hours a day, helps to move the air and generate a windchill, which fools your body into thinking it's cooler than what it really is. At the same time, it's saving on energy costs by not having to run your AC as much, because the dehumidifier is removing the humidity.
Just remember, the higher the setting, the higher the humidity level will stay. The lower the setting, the more humidity will be removed and the more comfortable you'll feel in the Summer.
And don't forget Routine Maintenance. Clean the air intake filter regularly. Clean and wipe down the refrigerant coils every 60 days. And don't allow water to remain in the collection bucket to long. As mold can build up in it.
Speaking of which, the water in the bucket, when fresh, is great for watering house plants. Because, when it's fresh, it's distilled water. No chlorine or minerals.
on May 04, 2011 | Maytag M7DH45B2A Dehumidifier
I have a fdl70s1 and will only work in continuous mode.. Collects water fine but turns off when I adjust humidity setting
I appreciate your post, Lee Silvey!
I understand that your Frigidaire dehumidifier, FDL70S1, will only work in continuous mode. Sounds like you could have a possible issue with the sensor or control panel. Are you under warranty? I would advise you to speak with your manufacturer to see if any further resolution can be provided. -Matt
Oct 15, 2014 | Frigidaire 70-Pint Dehumidifier -...
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
A friend let us borrow hers she used it once and we used it last summer in our basement, this year my son turned it on andit just gothot after several hrs but no water. so we have it in the bathroom with...
Kate, There are several basic things that can cuse the problem you seem to be having. At least you're doing the steamy bathroom test. You must have read one of my relies to someone else.Keep in mind, the lower the humidity extraction percentage or number, the more humidity it will take out of the air.
1. The air intake filter is dirty or clogged.
2. The humidity extraction level is set to HIGH. Lower it to 32%.
3. Obstructed air flow around the unit. You must maintain a minimum of 12" clear air space around the entire unit, while in operation.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. This is true in basement applications and the unit will not function properly. Unless it's a Low Temperature unit. Placing it up off the floor on a sturdy table or counter top that can adequately hold the weight of the unit, plus a full bucket of water, usually solves that problem.
Worse case scenario, the compressor needs to be recharged with refrigerant gas (R14). But, that doesn't happen that often.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 11, 2011 | Haier Dehumidifiers
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
Have classic dehumidifier model#CDR4500E. Can't adjust it automaticaly to come on or shut off. Don't understand the keypad fuctions, booklet to confusing.
Your dehumidifier preset default humidity level of 70%. Which is rather high, if you're using the unit in the hot Summer months. You can override this setting and lower the humidity level in increments to as low as 35%. Which is ideal during hot, humid weather. The Air Down button lowers the humidity level.Once the level is set, the unit will cycle ON and OFF as necessary, to maintain the level of humidity.
I have looked at the Owners Manual for you unit, and it's very thorough. But, I can understand, if you're not familiar with how the units work, it could be confusing. Page 5, is very informative on how to operate the unit, as far as setting humidity levels, which is what's important. If the operation of the unit continues to be a problem for you, contact Danby Customer Support 1-800-263-2629 and they can walk you through the procedures, while on the phone with them.
Hop this helped you. Please let me know. Thanks.
May 18, 2011 | Danby DDR2509EE Dehumidifier
My humidifier dont collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Maytag Dehumidifiers
Dehumidifiers Logo
81 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
