The valve has a cartridge that controls hot and cold water mixing.
the valve at one time had a smaller spindle built into the valve to prevent scolding. this item is located in the right hand side of the valve behind the plate next to the cold shut off valve. there is also a hot shut off valve located on the right hand side of the valve. Most times it is the cartridge itself and this can be found at all hardware stores.
here is a link that shows ALL THE TUB/ SHOWER VALVES PARTS.
http://www.moen.com/shared/pdf/tl3450pt.pdf
Hope this helps.
