Question about E-Machines T2742 PC Desktop
Emachine T5224 Anyone know the trick to get to the recovery partition at system start up to do a full system recovery? F2 goes to BIOS, f11 is not reconized, ctrl f11 goes to boot menu. Any help would be great.
Repeteadly Press F1 during boot. Then at the menu press F8 to go to advanced options. Then select System Recovery, and you can get into the recovery manager to restore the original factory system.
Posted on Oct 29, 2008
I have Emachine T5224 and if i put in a dvd it wont work ,It should start up and download automatic but i cant hear anything moving..I dont hardly ever use it maybe been a few years what should i do?
Posted on Jan 14, 2013
Bootmgr doesnt work on my toshiba
If by boot mgr you understand the boot menu ..for to select the recovery or boot from disk ,,,it may need to go to bios settinsg by pressing F2 on start and in there look for the HOT KEYS .. and enable the f12 key or f11 after case..
If you are referring to a missing boot file ...and this massage is displayed when you try to ope (boot ) the computer ..it means the boot sequence is corrupted and you need to run the recovery partition or disk ..or reinstall the operation system from a boot-able disk ..
to do so ..go to bios and set the first boot device to be the cd /dvd ..save with F10 and restart with the disk inside..and press any key for to boot from cd ..
For recovery partition just press F12 on start and select the recovery partition for boot device ..or F11 if it has a direct recovery start by this key ..
follow the procedure and choose by the case repair or complete system installing ..
In second case you may loose data in the C drive ..including programs you have installed manually and were not installed by the manufacturer..
so ..if you want the files choose repair ..(either from recovery or from disk )
the command on repair if asked ..is fixboot ..(after you choose the hdd0 /windows)
Dec 08, 2011 | Compaq Presario CQ60-220US PC Laptop
I have toshiba satellite L305d-s5934, Blue screen error appear and hang, when i boot or when i press F2 to enter bios... if i full out the hard disk the computer says: no bootable disk and if i press F2 to...
Sounds like your HDD may have gone bad. What is the name/number of the blue screen error? Google it and see what it means. It may be possible to reinstall the operating system to the original factory settings using the recovery partition (this is usually accessed by tapping F10 or F11 while booting, although I read somewhere that you might be able to gain access to the Toshiba recovery partition by pressing "0" (zero) while the computer is powering on).
You can try to recover the computer to factory settings. If your hard drive has enough life left on it, you might be able to then clone it to a new drive. Drive Image XML is a free software that will do this for you (get that from www.download.com). This way, when you clone the drive, you will also clone the recovery partition, so you don't lose that option. Once you have a new hard drive up and running, use the Toshiba Utility to make System Recovery Disks for the future.
One more thing: If you have recently upgraded/replaced the RAM - this might be your problem. Put the original RAM back in and see if the computer boots. If so, you found the culprit.
Feb 26, 2010 | Toshiba Satellite L305D-S5881 Notebook
How to enter system recovery partition hp pavilion 7975
At start up go to the BIOS by selecting the proper F key. When in the BIOS mode look for instructions at the top or bottom of the screen to hit F keys like F10 for System Recovery.
Oct 29, 2009 | HP Pavilion 7965 PC Desktop
I have an eMachine t3516 that I would like to restore back to factory settings. I understand there's a recovery management partition on the HDD. how do I access it?
to access the recovery partition, reboot the machine. when you reboot the machine you will see at the BIOS skip screen "PRESS F2 or DEL etc... for System Recovery".
Aug 26, 2009 | Computers & Internet
Hp pavillion zv6000 no disks need full restore...
Yes, the recovery partition is 100% true, and I've actually used it to repair a lot of systems, simply because it saves you time, stress and energy.
It is always on a smaller partition on your hard disk, and it is also hidden, so you wont see it.
To use the recovery partiton, you have first of all take note that you must backup ALL your documents first, because the use of the recovery partition will Actually format your harddrives and restore your system back to the factory settings, i.e the way you bought it.
Now, provided your own recovery partition is still intact and not yet corrupt, this is how to use it.
When you power up your system, Keep tapping the F11 key, i.e the F11 function key.
This will invoke the command that boots up your recovery parttion and lets your system boot from it.
Thereafter, you can just follow the on-screen instructions to complete the recovery, and again PLEASE remember to backup ALL your necessary documents first.
Hope this helps you out.
Goodluck
Jul 10, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
How to recovery the system from recovery partition
As far as I know (I have a Toshiba though a few years old now) and do a Recover to Factory Default state from Hidden Partition every 6 to 9 months and I hav enever been told to Tap F1 but instead Hold down "0" i.e he Zero button on my laptop as I turn the Laptop On from an Off state by pressing the Pwr Button and ONLY release the "0" button when I get a Recovery Meny with 4 Options I think.
Your Model might be a different Button on the Keyboard so PLEASE check your User Guide/Manual for instruction.
regards,
Bastian
Apr 09, 2009 | Toshiba Fusion Satellite U405-S2833...
Did you know you only get ONE shot at creating a recovery disc? And most of the time it is garbage, just like Vista.
He tried to put XP on it and failed? weird.
A couple things you can do...
1. Get your hands on a Vista disk. If you know anyone that works in IT, you can borrow a Vista disk. Do a complete fresh install. Use your "Product Key" and you will have your own Licensed, perfectly legal version of Vista.
2. Get yourself a copy of XP. Delete all partitions, then create a new one. Don't try to save that Vista recovery partition...it's toast. I recommend XP, but I'm a dinosaur.
Apr 07, 2009 | Toshiba Fusion Satellite U405-S2833...
Operatings systems disc not working properly
The cd that you got with your system may be a recovery cd; not an operating system disc.
Dec 17, 2008 | E-Machines Open Box D3107 AMD 1.8G 256M...
Formatting dell laptop 1420
Hi, Most dells sold in the last 4 to 5 years are sold with a recovery partition on the hard drive. what this means is you should not need any disc`s to do a recovery, unless you have replaced the hard drive. A little trick that most people dont know is that you only need to hold down the CTRL and F11 for a few seconds. Remember you need to do it a s soon as the laptop powers up, you should be given a menu asking you if you want to do a repair or full recovery. if you choose full recovery the the laptop will be restored to factory settings.... hope this helps
Tony A
Dec 12, 2008 | Dell Inspiron 1501 Notebook
My emachine computer is to slow.
I just did a complete recovery to an eMACHINE COMPUTER without the disc that comes with the comp. first step is to save any document , files , photo , music & video to a CD-R , external hard drive , or another comp. when ready turn on comp. yor gonna see the initial black screen with the big " e " following the technical data information , look down where it says RECOVERY and follow instructions , hope this helps
Apr 28, 2008 | Computers & Internet
E-Machines T2742 PC Desktop Logo
2,423 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
