Question about Maxon HCB-10C CB Radio
My HCB 10 transmits a carrier but has no audio. Reciever is fine. Where do I get a schematic?
  • 391 Answers
Hello there ,a very simple solution to this problem remove rear covering and circuit board you will notice the mic anylise it for wire breakage or dry solder joint iff you have a replacement mic you can replace it ,if this fails its more than likely your audio chip has given up ,its best to leave it to someone with expertise goodluck ei5glb
Posted on Apr 07, 2011
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Cb is recieving but not trnsmiting
Ah! these and the cobra 2000 had the same board and same problems--
Some will have no transmit audio (check or sub to make sure microphone not the problem) and others no receive audio.
If circuit problem both are caused by a filter cap that opens.
Usually this occurs when radio has not been used for a long period of time.
If you have a schematic for the radio (mine are all out of reach) you will find in the audio circuit a cap (I think it is 220 uf at 10 volts) right near where the volume is controlled that is bad.
The no transmit audio problem is another cap in the mic circuit.
I hope this helps you as it is likely your problem--note if the audio output IC was bad no receive or transmit audio.
shoot me a question by using the make comment if you need further help.
73's
Mar 23, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Shematik
There are no manuals or schematics for that radio. You may have to call MAXON and have them send you one.
Nov 17, 2011 | Maxon HCB-10 40-Channels Handheld CB Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Apr 29, 2010 | Onkyo TX-DS575 Receiver
Schematic diagram for 5630 yamaha reciever
http://www.eserviceinfo.com/downloadsm/36410/Yamaha_HTR-5630.html
Mar 04, 2010 | Yamaha HTR-5630 Receiver
No modulation with strong carrier
sounds like your Audio Output went out......not audio chip....may be your voltage regulator also....your voltage regulator IC is heat sunk....do you have a schematic?
Jan 23, 2010 | Cobra Radio Communications
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
Rci 2950 no audio period rx or tx
Check TR38 I have seen caps in the circut
go bad more then once if you have a schematic you should be able to find it if one
is bad,a capasator meter would help but you
can check them with a ohm meter.
Good luck.
Nov 21, 2008 | Radio Communications
Maxon HCB-10C CB Radio Logo
166 people viewed this question
Top Maxon Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
