Question about HP Pavilion dv5237cl Notebook
Drive shows in device manager but not in my computer.so can not play anything
  • graeme ian hunter Dec 29, 2010
    hard drive or optical drive?
  • 2,229 Answers
When this happens, the hardware is recognized but the drive has probably gone bad. I would recommend replacing the drive. var fctb_tool=null; function FCTB_Init_ab0f421bee8048f7b0952c82e14fbd4d(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_2b0fb69882a443e693d3245e53a158c0(t) { fctb_tool=t; start(fctb_tool); }
Posted on Dec 29, 2010
Cd player dont work
Is it a CD player? Are you trying to play DVDs? Does the CD player show up in device manager? (Right click "My Computer", click Properties, Hardware Tab, Device Manager. If it doesn't show up at all then the drive probably needs to be replaced.
Nov 30, 2011 | Computers & Internet
Hello my DVD drive will not play and will not show
Can you check whether you Disc Drive is well connected ?
to check the device :
Right click on my Computer
Select Properties
Hardware devices
Device Manage :
Check your Dvd/cd drives.. whether everything is connected.
If not try re-installing the device or to update it.
or try this
go to start
right click on my computer
click on manage
then click on storage
then click on disk management
then right click on your device and select add letters and path
window will pop up then click on add
the select an alphabet and click on ok
Hope your problem got solved. Thanks
Apr 20, 2010 | Toshiba Satellite L305-S5911 Notebook PC
I put this system in my truck and the dvd player wont work on it
Please try to download the codecs and also try with the un-installing the DVD drive from the device manager.
Codecs weblink : http://www.free-codecs.com/K_lite_codec_pack_download.htm
Copy and paste this web link in the address bar.
Locate " Download [ K-Lite Codec Pack 5.6.1 FULL ] " from the list and click on it to start downloading the codecs. Once the download is complete, please double click on the downloaded file to install.
To uninstall and re-install the CD/DVD drive, please follow the below steps :
For Windows XP :
Click start >> Run >> type devmgmt.msc in the text field and click OK.
This will open the device manager window.
For Windows Vista and Windows 7 :
Click Start >> type devmgmt.msc in the start search field and hit enter key on the keyboard.
You will see a list of devices in the device manager window.
Click on + sign beside the CD/DVD ROM listed there. This will open the name of the device listed there. Right click on the device name listed there and click uninstall from the dropdown list.
This will disappear the device name from there.
To re-install the CD/DVD ROM drive :
Click on Action tab from the top of device manager window. Click Scsn for hardware changes from there.
This will re-install the CD/DVD drive in the device manager.
Try playing DVD's and check for the issue.....
Jan 17, 2010 | Pioneer AVH-P4000DVD Monitor
My computer isn't seeing the D Drive at all how can I resolve this
go to control panel, system, hardware manager. .and see if it's showing up there..if not,try scan for hardware changes..of course, if you provide the operating system and computer type that will help too.
Dec 06, 2009 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
External Hard Drive connected but hidden !!!
Connect it to your computer.
Right click on my computer and select Manage
On the left side click on Disk management.
Now on the right side, look around and see if you spot the external drive there.
What do you see there?
Also look into device manager, then look for anything with ! or ? yellow marks.
May 03, 2009 | Western Digital WD Passport 250GB Portable...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Acer aspire can't find the dvd to play cd's
In the device manager, select the DVD ROM and UNINSTALL / REMOVE the device.  Restart Windows . . . did this work?  If not, boot into your CMOS and see if the drive is being detected by the motherboard... if yes, look further and make sure the settings for the drive are correct. Make sure that all IDE interfaces are enabled in the CMOS settings (both)
Dec 13, 2008 | Acer Aspire 5315 Notebook
Sandisk crezer 4GB micro wont work
Try this,
Note:I assume you are on win XP.
Right click on my  computer and click manage.
Now on left side please select Device manager and look on the right side if you have any device that says "Unknow Device" or any device that is showing an Exclaimation Mark. If any of this exists then right click on that and uninstall. After this unplug your Flash drive and restart your computer and try inserting flash drive if it works or not.
If not, again go to device manager and expand an option that says "Disc Drives". Please check if it shows anything related to your Cruzer Flash Drive. If it's there, then go to Disc Management that will be there on left side of this same window. There, you need to look for your Removable disc and right click on it and click change drive letter. Now choose a different drive letter preferable one of the last alphabets like Z. After this click OK and now try going to my computer to check if it appears or not.
Moreover, if none of these solutions work please get back to me with some more info like if you have U3  on your Cruzer that comes preinstalled on your flash drive and the version of your OS.
Nov 23, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computer Freezes
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
HP Pavilion dv5237cl Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
