Question about Panasonic Electronics - Others
We have an air conditioner unit,18,000 Btus. When we turn the unit on, it began to works fine, but after a couple of hours,the unit turns off and the timer light began to blink. The code of the troubleshooting (90) means, Power factor correction abnormality. How can we solve this problem.
  • Panasonic Master
  • 43,501 Answers
The first thing that I would do is buy one of these and see if it works....cause if it don't then the alternative is some very exspensive equipment....
http://cgi.ebay.com/New-Electric-Saver-Power-Factor-Correction-PU-1200-KVAR-/220714759637?pt=LH_DefaultDomain_0&hash=item33639ff5d5
Installing one of these should not only save you the trouble you are having now, but also save electric.........
This is not my product, but I do have a similar product installed in my home and they do work...
heatman101
Posted on Dec 29, 2010
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    LG air conditioner blinking red power light
    This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
    Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
    Works for an hour then blows warm. shut it off for two or three hours and it works for another hour or two. unit is two years old 18,000 btu unit
    Clean the outdoor coil, slide it out of the case and use a garden hose to it, keeping water out of the rest of the unit, sounds like the coil is dirty, clean it good until the water runs clean every inch of the coils and you should be running again.
    Jul 05, 2011 | LG Electronic Window Air Conditioner
    I recently came to home to find my furance (natural gas) running but it was blowing cold air. I pulled the filter, it was dirty, cleaned it and replaced it. I turned the furance back on and it worked...
    You are resetting it every time you take the panel off the front of the unit. It is locking out the circuit board. No. 1 reason for this is a dirty sensor. The flame sensor is the small rod-like part that senses the flame of the burner. It is usually pretty close to the hot surface ignitor (the part that glows bright when the furnace is igniting) Watch your furnace burner light. You will see the ignitor come on. The sensor is a little bigger than a pencil lead and it will be just a couple inches away from the ignitor.
    Take the sensor loose and clean it only with fine sand paper or emery cloth. Chances are this will solve your problem. Hope this helps
    Apr 21, 2011 | Heating & Cooling
    How many VoltAmps does the LG LS-K1830CL consume?, What is the voltage?, Mono or 3 fase?...
    BTUs: 18,000 (C)
    SEER: 10
    Interior Voltage: 36
    Voltage: 208/230 VAC
    Maximum 8.5 amps
    Single phase.
    Is it helpful?
    Dec 28, 2010 | LG LS-K1830CL Cool Mini Split Air...
    My model is AEV05KB and recently I see water on the cooling pipes sometimes it drips and sometimes it forms snowlike formations and also if I put the cover on the snow completely coveres the parts inside...
    It sounds like the unit is too small for the area being cooled. You should figure the square footage of the area and use this th figure what you need.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Using the square footage and the chart below, determine the correct cooling capacity. Cooling capacity is measured in British thermal units (BTUs) per hour.Area To Be Cooled (square feet) Capacity Needed (BTUs per hour)
    100 up to 150 5,000
    150 up to 250 6,000
    250 up to 300 7,000
    300 up to 350 8,000
    350 up to 400 9,000
    400 up to 450 10,000
    450 up to 550 12,000
    550 up to 700 14,000
    700 up to 1,000 18,000
    1,000 up to 1,200 21,000
    1,200 up to 1,400 23,000
    1,400 up to 1,500 24,000
    1,500 up to 2,000 30,000
    2,000 up to 2,500 34,000
    Make any adjustments for the following circumstances:
    If the room is heavily shaded, reduce capacity by 10 percent.
    If the room is very sunny, increase capacity by 10 percent.
    If more than two people regularly occupy the room, add 600 BTUs for each additional person.
    If the unit is used in a kitchen, increase capacity by 4,000 BTUs.
    Consider where you install the unit. If you are mounting an air conditioner near the corner of a room, look for a unit that can send the airflow in the right direction.
    Jun 17, 2010 | Heating & Cooling
    Need new one
    Air conditioner equipment power in the U.S. is often described in terms of "tons of refrigeration." A "ton of refrigeration" is defined as the cooling power of one short ton (2000 pounds or 907 kilograms) of ice melting in a 24-hour period. This is equal to 12,000 BTU per hour, or 3517 watts.[13] Residential central air systems are usually from 1 to 5 tons (3 to 20 kilowatts (kW)) in capacity. To determine the correct size keep in mind that 12,000 BTU's equals 1-ton. Use the table below to determine the size AC that you need. Hope this helps. Area To Be Cooled (square feet) Capacity Needed (BTUs per hour) 100 to 150 5,000 150 to 250 6,000 250 to 300 7,000 300 to 350 8,000 350 to 400 9,000 400 to 450 10,000 450 to 550 12,000 550 to 700 14,000 700 to 1,000 18,000 1,000 to 1,200 21,000 1,200 to 1,400 23,000 1,400 to 1,500 24,000 1,500 to 2,000 30,000 2,000 to 2,500 34,000
    Jan 08, 2010 | Intertherm P3RA-048K Air Conditioner
    Electronics - Others Logo
    171 people viewed this question
    Top Panasonic Electronics - Others Experts
     Grubhead
    Grubhead
    Rod
    Rod
    Tom Chichester
    Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
