Question about CIBA Vision Gigaware 2.0MP Webcam
What is the correct way to install the gigaware 2.0 mega pixel camera w/ auto focus lens.
I have a Gigaware 2.0 Mega Pixel Auto Focus Lens. I usually turn the auto focus off, and it works fine. But now, I turned off the auto focus, and it's still blurry. I already tried re-installing software...
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Oct 29, 2013 | Radio Shack VGA PC Camera Webcam
Canon rebel xti focus issues
this does not seem to be like a problem in settings
please use a different lens and try the same
Aug 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Installing webcam software
Dec 06, 2012 | Micro Innovations Gigaware 1.3 Mega Pixel...
The focus is blurred and when you use the zoom it still will not focus. My camera is a Konica Minota Dimage Z3 4.0 mega pixels.
lens including the focousing unit must be serviced,while u focous press click button half way till u get green led glow,then click.
Apr 09, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
Drive camara web gigaware 2.0 mega pixeles
Radio Shack Drivers ?
http://support.radioshack.com/soft.htm
Nov 10, 2009 | Radio Shack VGA PC Camera Webcam
Lens is fuzzy
Lens barrels are not in correct position, therefore, no focus. Needs service. No way to RESET lens barrel position. Needs service.
Mar 18, 2009 | Casio Exilim EX-Z57 Digital Camera
Instalacion de camara gigaware
Hola,
Descargue el primer, si es para el Windows XP, descargue el segundo uno, si es para el Windows Vista.
Y hay instrucciones para el webcam, pero ellos son para inglés :(
Gigaware VGA PC Camera (Original Drivers for Windows 98SE/ME/2000/XP (11.9 MB))
Gigaware VGA PC Camera (Vista Standard WHQL Driver (14.7 MB))
Gigaware VGA PC Camera (User's Guide)
¡Buena suerte!
Chris (ziraffa)
Dec 28, 2008 | Radio Shack VGA PC Camera Webcam
Focus
The little white ring on around the lense, that is the focus on the camera. Now the other issue with picture quality is the camera itself. I believe this camera only 1.3 mega pixels to get a less blurry higher quality pic u should use a higher mega pixel camera
Nov 12, 2008 | Logitech Quickcam Chat Webcam
Samsung digital s73 camera
Hi, there are many reasons why a camera may produce less then sharp pictures.
1) Dirty, oily or damaged lens: Check for dust and fingerprints.
Clean lenses with extreme caution, using dry lens paper.
Use only minimal pressure and gently wipe from the center
outwards, NEVER in circles.
If the lens is really dirty, ask a professional photo dealer to
clean it for you as a free courtesy.
2) Check to see if the auto-focus is working correctly, this could
be an electronic or mechanical problem requiring servicing.
Focus the camera on sharp image at various distances,
to see if it responds by moving the lens.
3) Can you focus the camera manually?
4) Can you focus by moving the camera back and forth
in regards to the object of interest?
5) Is the auto-focus feature somehow disabled in the menus ?
6) Are the batteries up to snuff, they may be strong enough to
turn on the camera, but too weak to move the focus motor.
7) Is the subject you are trying to focus on out of the
focus range of the lens: i.e. too close ?
8) Is the subject you are focusing on too bland, with insufficient
detail to activate and lock the auto-focus.
9) Do you have enough light for the auto-focus to operate.
10) Does the flash unit project an red pattern to help with
focusing.
11) Are you mistaking sharpness (focus) for depth of field.
In low light conditions, the lens iris opens wide, just
like your eye, to let more light in.
This results in a loss of focussed depth of field. This
means that focusing becomes much more sensitive
and critical, such that (when) the main subject is in focus,
everything behind and in front of the subject is not.
This is a theoretical limitation of all optical lenses:
The greater the focal length and the greater the aperture,
the shorter the depth of field.
This can actually be very beneficial when shooting a
portrait: Focus on the eyebrows, blur the background,
or it can be very detrimental: When trying to magnify
a butterfly on a tulip in low light conditions, getting
everything in focus is impossible.
12) Are you mistaking motion blur with lack of focus,
due to slow shutter speeds.
13) Are you shooting in very low light conditions,
causing the picture to become more noisy,
due to the way the digital camera sensor works.
14) I you come up empty on all these suggestions,
you probably have a defective camera and it is
warranty time:
a) Defective electronics
b) Defective auto-focus mechanism
c) Defective lens, loose internal elements
d) Detached sensor chip
.... etc
Try to isolate the problem. Try to manually and
automatically focus on a wide range of subjects,
at various distances, in bright daylight conditions.
If you are still unable to focus the camera,
it is probably defective and requires replacement
or servicing
BTW
Quick review of the internet, indicates that
this particular model is notorious for high battery drain
and battery connection problems. This may be the cause
of poor auto focus as indicated above.
Also this camera has insufficient internal memory, and
and an add-on memory card is required. It is possible
that without the memory card, the camera is defaulting
to a very low pixel resolution, in order to save memory
space, thus creating the appearance of poor focus.
The nominal resolution of the camera = 7.2 Mega Pixels
is respectable for such a low cost camera, but the
reliability reviews are not good.
Martin
Apr 24, 2008 | Samsung Digimax S730 Digital Camera
CIBA Vision Gigaware 2.0MP Webcam Logo
102 people viewed this question
Top CIBA Vision Computers & Internet Experts
David Payne
David Payne
Are you a CIBA Vision Computer and Internet Expert? Answer questions, earn points and help others
