Question about Autodesk Lightscape 3.2 Full Version for PC
Installation of Lightscape 3.2 stops with error message: incompatible with 64 bit version of windows.
    Genius:
  • 1,288 Answers
I found a workaround, as this programme does not work with Vista 64bit, you can review it here a see if it helps:
http://forums.cgarchitect.com/26663-lightscape-batch-vista.html
Seems like a nightmare to do it though...
Posted on Dec 29, 2010
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
While installing games ..window opens and says "can't start or run due to incompatibility w/64 bit version of windows"
Yes, this is a really big issue, in that 32 bit machines are (apparently) no longer made, and that renders lots of software useless. Look for a 64 bit version of the game that you want to install.
Aug 27, 2011 | Computers & Internet
I have Quicken Expensable 98 Version 3.5. When I try to install it on my Windows 7 computer it says that the version is incompatible wth Windows 64 bit. What can I do?
It won't work under Windows 7 64-bit, it's non compatible but there is a very small possibility it could work under a 32-bit system .
If you have an install disc of a previous version of Windows , you can easily install a virtual OS on your HDD with WMWareplayer from : http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
Safe , easy to install and use , no specific knowledge required .
Best regards .
Feb 02, 2011 | Computers & Internet
New computer has windows 7 - when trying to install printer I get an error message that it won't support the computer system
Perhaps you are using the wrong driver set. Download the driver from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3795406& . Use the drop down menu to select Windows 7 32-bit or 64-bit then select Next. For best results get the Full Software from the section labeled Driver Product Installation Software. Then if needed, return to this page for the Updates to improve the reliability of the network connection and the scanned file storage.
If you use a print server, that unit may be incompatible with Windows 7. You don't need it with the 6500 (E709n if your router is Wireless 802.11 b/g compliant).
I hope this helps. We have the wide-format version of this printer on a wired network (3 Win7 machines). Our unit came with two CDs - only one was appropriate to our installation. The other wouldn't load.
(to check which version of Windows 7 you have, click Start > Control Panel > System and Security > System. If you have x64 in the title get the 64-bit driver. The 64-bit OS requires signed drivers.)
Jan 22, 2011 | HP Officejet 6500 Wireless All-in-One...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I bought a new computer. When I tried to run
To be honest, there are only two options.
1. Go to the sierra online website and see if you can get a 64 bit version of the game
2. Get an entirely new OS of windows (a 32 bit version) and then try installing
Feb 24, 2009 | Sierra Online, Inc. Hoyle Classic Games 2...
Acer incompatability with iTUNES
I think Steve is correct, it's sounds like XP 64 bit or a Vista issue.
Are you going to let us know?
Aug 09, 2008 | Acer Aspire 3680 Laptop
ITunes problem with Acer
this is because of the incompatibility of the software with the windows.
formatting your pc would help solve your problem regarding on downloading the itunes and software for your printer.
Autodesk Lightscape 3.2 Full Version for PC Logo
438 people viewed this question
Top Autodesk Computers & Internet Experts
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
