Question about Kitchen Ranges
We have a Brewmatic 9720013 AKA- Macco SIRIO R2 that is indicating a L motor error 13. No manual is available and I need to know if you can get me one online ASAP.
2 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: VAX Petvax Operating Manual
Check Vax.co.uk they have an online user manual section.
Specificially:
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Dont forget to rate appropriately, thanks.
Posted on Mar 27, 2009
Need a free manual for 1966 Mercury 3.9 hp outboard motor.
Don't use WD40, it is paraffin AKA coal oil
Sep 10, 2016 | Boating
Hi I am in need of a manual for a macco mega coffe machine BG2004 IVA 0268821016
I suggest that you google the make model and manual .Or contact mfg's website for tech support
May 11, 2015 | Coffee Makers & Espresso Machines
Error 13 on epson dfx 9000 printer
Hi Good day!!
Error 13 is a printer error code that signifies that there is a paper jam. You need to check the jam in the entry if your system shows this error. Error 13 also indicates the need to replace the pickup roller in the printer.
Aug 29, 2012 | Epson DFX-9000 Matrix Printer
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
Getting error on machine E014 what do I do
This error usually indicates that the fuser drive motor cannot drive, or rotate properly. It could be a seized fuser assembly, (aka Fixing unit), broken drive mechanism, faulty DC Controller PCB.
It can also be caused by unstable rotation of the fixing assembly, or main motor.
Jan 27, 2010 | Canon imageRUNNER 400S Copier
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
40 MIO ERROR
HP's support document on error 13 paper jam:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=25484&prodTypeId=18972&prodSeriesId=25484&objectID=bpl01309
According to my "HP LaserJet Family Quick Reference Service Guide, Vol. 1", on page 38 and 39:
40 Error (data transfer error)
(among other possibilities, these two seem most applicable:)
- The MIO card is unseated or defective - remove, reseat, or replace the MIO card
- An abnormal connection break occurred while transferring data from the computer.
The manual further indicates that a 40.1 means the MIO in slot 1 has the problem; a 40.2 means the MIO in slot 2 has the problem.
I'd try turning the printer off and reseating the card, and if that doesn't work, try swapping it out if you can.
let me know if you need further assistance, Joe
If it helps.please rate this solution.
Feb 18, 2009 | HP LaserJet 4m plus Printer
Printer Acting strangely - red led appears after 13 seconds.
If the red error light is on by itself this indicates a Fatal Error: Fatal error indicates one of the following: ? HP sensor lever or PE sensor lever does not move smoothly. ? HP/PE sensor is defective. ? CR motor is defective. ? PF motor is defective. ? Main board is defective. ? Printer Housing is not secured with screw on the printer mechanism. You could try reflashing the firmware which sometimes helps to rectify this error.
Jun 05, 2006 | Epson Stylus C20SX InkJet Printer
Kitchen Ranges Logo
91 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
