Question about Polk Audio PSW140 Speaker
Wondering what the 2nd input (red jack) on my PSW140 is for and what the frequency should be set to.
    Brigadier General:
  • 8,546 Answers
A single or mono bass-specific input would be attached to the one marked LFE (usually the Right).
The sub also supports a full-range stereo signal coming into it on both jacks if your electronics don't break out the LFE to one output.
Posted on Dec 30, 2010
Trying to set up digital set top box to our old LG tv model no CF-21F80KX . Have red white and yellow on set top box and 2 white and 2 yellow on back of tv. Kerrie
The RED and White RCA jacks on the set top box are for Right and Left channel audio to go into the TV Video 1 or Video 2 input jacks of the TV. The Yellow jack is for the Video, that will go into the Yellow jack on the TV Video 1 or Video 2. If you want to use Video 1 INPUT, then all 3 jacks (RED, WHITE, YELLOW) will be use. Just match the color, they should be grouped together per each set of input on the TV.
I hope I explain it well enough.
Mar 24, 2011 | LG Televison & Video
Hav nad 2100. I dont understand what the lab in post are for?
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use them UNLESS you have a turntable source.
Feb 23, 2011 | NAD C325BEE Amplifier
As soon as I turn it on I get a low-mid frequency hum and no sound from other sources comes through...
Does the hum occur when the levels are all the way down?
1st thing to check is for a broken input jack
2nd thing would be power supply capacitors gone bad
Aug 14, 2010 | Samson Servo 170 Amplifier
I need to connect my Panasonic DMR-E85H DVD to an old HMV TV. I need to know what the frequency of the out pout would be for the A1, A2, A3 output channels from the DVD and what the input frequencies...
It doesn't use TV channels, it uses AV, Audio Visual, input. That means you hook up, to the, whats called the EXTERNAL Inputs, A1, A2, A3, these are the external inputs that relate to the Jacks on the rear/side of the unit. You use the output from the DVD, and hook it up to the AV input on TV. Press Play on DVD and Select, correct external input on TV. Usually it;s Yellow to Yellow Red to Red and White to White.
Mar 02, 2010 | Panasonic DMR-E85H DVD Recorder
I do not have a manual, how do I hook this dvd to the tv? I have one cord with yellow, red and white connections, cannot make it work. Thank you
If your dvd player is a high definition player you will need to connect your dvd to your unit with YPbPr connector cables. the come with 5 or 6 jacks (red,green,blue,yellow,white) (sometimes you may find and extra red jack do not plug the 2nd red jack in. Ground it so that way it's not touching any of the other input jacks). Change your input source whenever you go to use your dvd player or turn your auto source on. You can retrieve a manual from your tv's manufacturer website. It will be available for download.
Aug 04, 2009 | Akai DVPS7000 DVD Player
No rcas inputs on amp
Hello sting_ya_sco,
The ACAP501Q has 2 sets of of RCA jacks. The first set is input and 2nd preamp outputs. The jacks are factory covered with plastic protectors. Just pull the protectors off and plug in the cables.
Hope this helps.
Jul 25, 2009 | AudioBahn A2002T Car Audio Amplifier
I want to connect my ps3 via hdmi cable to my magnavox 51mp392h/17 hdtv but theres no hdmi jack on my tv what to i do?
If there is NO HDMI on the TV, There are 2 options to still get HD. 1. Check if your TV has a DVI input, If it does you need a DVI to HDMI converter. This can be a problem with some TV models it might not sync up 100%. 2. I recommend doing this, Purchase the Component Cable For the PS3 from Best Buy or any Game store. Make sure it is the ONE for the PS3!!!!!!!!!!!!!! This cable will give you up to 1080i resolution and stereo Audio. Plug in the Red, Green and Blue into the Component (R,G,B) Input in the TV, The Red and White (audio) will follow into the same Input (White and Red) just match the colors from the cable to the TV. On the PS3 in the Menu go to the 2nd row from the Left and down to DISPLAY SETTINGS. Select Component (under HDMI) check off everything except 1080p and then SAVE by pressing X. If you have a Receiver (AMP) that your Audio goes into, Then you can buy an Optical Cable for Surround Sound. Plug in the Optical cable then on the PS3 go into the menu, 2nd row, Sound Settings, Choose Optical, Then choose Auto and SAVE! Hope this will Help!
May 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Does this model have a digital input?
This model does not have a digital input at all - only red and white inputs.
Mar 15, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
Turntable setup into an hp 7590
In theory as long as you have a sound card installed, yes you can connect your turntable direct to your computer simply by connecting it to the audio input.
You will probably need a patch lead with twin line phono connectors on one end and a stereo 3.5mm jack plug on the other end.
Please note, the turntable or phono inputs on amplifiers are unlike all the other inputs, because they have a particular frequency response tailored for use with a headshell cartridge.
If you connect your turntable to an input that has not been tailored to the RIAA response curve, it will sound tinny. This is what probably happens when you connect to your computer. The input may also not be sensitive enough.
You may be able to adjust the frequency response if your sound card includes an equaliser. Alternatively, you may be able to download some audio software that will allow you to equalise your turntable.
All in all though, I'm sorry to say you would be better off with an outboard preamp.
Mar 08, 2008 | Technics SL-1200MK2 Turntable
Polk Audio PSW140 Speaker Logo
240 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
