Question about Toshiba 57H82 57" Rear Projection Television
I have a toshiba 57hdx82 got it in 04 replaced the scan converter in 07 and now almost 2011 the set is giving me a convergence error the red and blue crosshairs are fine cant get the green to go straight and it is a curving line at the bottom of the screen ive also lost the remote for it anyone got any awnsers
  • Toshiba Master
  • 8,457 Answers
The tv have convergence problems again and again that the DLP tvs design flaw weakness.The tv convergence board must have it 2 STK convergence ICS and some or all resistors to be replaced to solved convergence cross hair - + to lines up,to solved tv convergence picture mis colors lines R,G,B mis alignment.The shop,will cost u like $300-350 for parts and labors.
Posted on Dec 29, 2010
    Brigadier General:
  • 8,909 Answers
It sounds like it has cost you a fair bit of money over the years. It would be great to get it going again but if you stand back and look at what it may cost, would it not be wiser to put your money into some more modern technology?
Convergeance errors are unlikely to be easy fixes. I expect the power supply is getting noisy and producing distortion on your picture. Replacing the many aged capacitors will possibly repair it.
Hope that helps.
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
Convergence function reads error
Check the 1.8 ohm resistors in the convergence circuit there will be 6 all 1.8ohms, They will be where your STK ICs are
STK392-110s which are Big Black ICs,You may need to replace ICs They are Big Black ICs with STK392-110 printed on them Mats has them 1-800-628-1118
May 30, 2010 | Toshiba 51H83 51" Rear Projection...
Red gun convergence problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 16, 2009 | Toshiba 65HX81 65" Rear Projection...
Toshiba 42H82 Blue raster is bowed to the right in the middle to the rt. The auto convergence give an error.
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 16, 2009 | Toshiba 42H82 42" Rear Projection...
The blue convergence will not move left and right
The convergence Ic`s need to be replaced, in the future give your model number it helps us to give you more info, video-tek
Feb 07, 2009 | Toshiba Televison & Video
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
