Question about Samsung C3053 Cell Phone
Cable is not loaded. - Samsung C3053 Cell Phone
  • 36 Answers
Problem with your cable.contact samsung service center.
Posted on Dec 29, 2010
It doesn't load paper,when paper was load in a tray,the paper was loaded in jam and also gone in bango.
Welcome to FixYa.
If the printer don't load paper, please follow the following steps.
1. Check the printer make sure no scraps of paper are stuck inside the printer.
2. To check remove the door at the back of the printer.
3. If you paper try to pulled the paper jam.
4. Double check again if there is scraps of paper.
5. Then put back the door of printer.
6. Then, Disconnect the USB cable from the printer.
7. Disconnect the USB cable from the computer.
8. Leave the cable unplugged for 5-6 seconds.
9. Reconnect the cable to the printer and computer. Ensure the printer is connected directly to the computer through a USB cable or power USB hub.
10. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How do you wire a GFCI light switch and outlet combination? There are 2 black wires coming out directly from the back of the switch side.
If I understand correctly, you are replacing a single switch that has two wires.
You want to install a switch/plug-gfci similar to one shown below.
You are working on wires inside a box:
To wire this kind of device you need at least 2 cables entering the box.
Each cable has a black-white-ground wire.
Cable 1) One cable comes from breaker box. This is the Hot cable
Hot cable has black-hot-from-breaker & white-neutral-from-breaker
Cable 2) One cable goes to the Load (light, fan motor). This wire is controlled by the switch. This is the Load cable
Load cable has black-to-load & white-to-load.
Leviton combo GFCI and Switch
There are 2 screws on either side of switch
There are 2 screws to either side of plug
There are two wires on back of device
2 screws on either side of switch: there is a brass-colored screw and silver-colored screw.
Black-hot-from-breaker connects to brass colored screw on side of switch
White-neutral-from-breaker connects to silver colored screw on side of switch
2 black wires on back of device
Black-to-load connects to black wire on same side of switch as brass-colored screws
White-to-load connects to black wire on same side of switch as silver-colored screws
2 screws on either side of plug
These screws are used when your box is a 'junction' box that feeds wires forward to another box ... for example you have 4 receptacles in a room, the cable enters first box and then goes to the next box and to the next box. Suppose your switch was one of the boxes. Wire arrives from a previous box (this is the Hot cable, every box has 1 Hot cable). Your switch box sends one cable to the Load (light, fan etc), but it also sends another cable to the next box which has a receptacle or another switch.
If your box has a third cable that feeds forward to other boxes, then the screws on either side of plug are used. The black-to-next-box goes to brass screw. The white-to-next-box connects to silver screw.
And all further boxes and devices are protected by the GFCI device.
If you need more information, please answer back and I will help.
Oct 24, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
I have a Tork 1101. I am confused by wiring diagram. Please help.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
1) Tork 1101 has 120Volt clock motor, making this 120Volt timer.
2) 120Volt circuit has 1 black hot wire and 1 white neutral wire and 1 bare ground wire. Ground wires connect to green screw and to each other.
3) You have two cables, each cable has black, white and ground.
One cable arrives from breaker box.
One cable goes to Load (light, fan, motor, pump etc)
4) Cable arriving from breaker box:
a) Hot black connects to terminal L.
There should be a brass connector plate that connects terminals L and 1. If this plate is removed, then add a jumper wire from terminal L to terminal 1.
b) white connects to terminal X
5) Cable going to Load
a) Load black connects to terminal 2
b) Load white connects to terminal X along with other white wire.
Aug 20, 2010 | TORK Variable Cycling Timer 8601
The Blue light does not turn on and my video does not wor. The System has power the Green Light turns on But the Blue light right next to it does not and I get no Video or sound.
the blue light only comes on when you insert a cd into the console and the cd has been loaded.it stays on permanently when the cd has been loaded and blinks when the cd is still loading.for the video make sure your av cable is properly connected and properly working.try testing your cable on another console or using another cable on your console.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Brother printer will not recognise usb cable I can load printer onto laptop through usb cable now want to load onto dell pentium 4 and keeps coming up does not recognise usb cable so keeps asking you to...
Try a new cable and a different USB port. It's possible dirt is making for a bad connection or that the cable is slightly damaged and this other computer is more sensitive to the problem.
I hope this helps.
(who has dealt with a damaged USB cable that didn't look bad and gave an intermittent problem with one computer and associated hardware.)
Apr 10, 2010 | Brother DCP 115C All-In-One InkJet Printer
I need to replace a shower cord but it has no instructions please advise on what wire goes where
Three wires in 3 out each set of 3 in a cable
Earth green/yellow attach to brass earth terminal on switch back - both cables and make sure that the copper wires have a plastic sheathing on them
input cable -
red or brown to live labeled 'L' on the terminal of the switch labeled 'IN' or 'MAINS'
black to the terminal labeled 'N' on the same part of the switch
Output to shower-
as above but to the part of the switch labeled 'LOAD'
The neon will be prewired to the LOAD side - take care not to disturb
To help to remember which cable is which, place a piece of tape on one cable to identify either MAINS or LOAD. Or red marker pen to the MAINS cable
Mar 23, 2010 | Home
How to hook it up to my computer
you can hook it by usb cable or network cable, usb cable just plug to machine and to computer and load the driver, network u have to hook cable from machine to router or switch, and u have to put ip address of the machine and load the driver
Jul 13, 2009 | Xerox WorkCentre Pro 423 Copier
How to load ring tones in nokia2600
u can load ringtones only by sms from other mobile phone(which act as a source of ringtone) thnx
Mar 01, 2009 | Nokia 2600
Bought a kodak 763 camera at Sam's wholesale
whats the exact model of your camera?
when did you buy it? exact date of purchase?
Nov 26, 2008 | Kodak D-22 (1756824) Dock / Cradle
Can't down load video from camera to new computer with vista ????
I don't have vista, but you might want to try a firewire (mini dv) cable, I know my computer crashes when I try to get the video from through the usb cable, but works fine when i use the mini dv cable.
Apr 28, 2007 | Panasonic PV-GS35 Mini DV Digital...
Samsung C3053 Cell Phone Logo
18 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
