Question about Samsung CLP 300 Laser Printer
Red light stays on... wont print wont pick up paper... cleaned as much as I could...
    President:
  • 670 Answers
There are a lot of conditions that cause the red light to come on. These include toner cartridge empty, paper jam, waste toner tank full, etc. The only good way of determining the printer fault is to check the smart panel software on your computer. It will tell you what the printer is experiencing.
If the printer can't pick up the paper, check the condition of the paper pickup roller. It is located in the back, and above the paper tray. Often it get dirty and cleaning it with a damp cloth helps it to pick up paper better. Hope this helps you.
Posted on Jan 09, 2011
Our Canon IR2016 after 10-15 paper print, then it stopping printing while I order to print, It appears "change papersize tray:a4" and red light flashing, thanks for your help
I wrote, some kind of the tip regarding these problem. Probably it wont help you much, but you can start to clean the paper pick up rollers and axis, try to remove the paper lint,by blowing her out and apply some wd40, or call service to replace parts with new ones.
http://www.fixya.com/support/r8933657-incorrect_paper_size_while_copy_in
Regards!
Apr 12, 2011 | Canon MF3110 All-In-One Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Printer shows a red light for paper. It will not
Remove the paper tray and clean the feed roller with alcohol or water.
Oct 04, 2009 | Brother HL-2040 Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Hp 2200d laserjet
possiably bad gear assembly.
Sep 21, 2008 | HP LaserJet 2200D Printer
Paper not picking up and alarm light comes on/stays on
Hi, You have the right idea of cleaning the rubber rollers behind the tray, (if the paper will feed through once then we can eliminate the idea of a paper jam)unfortunantly, when the rollers get too worn out then cleaning is not effective. I work on alot of Brother 5140 printers which look very similar to this model, and we pull out the tray,take the pick roller off of the printer, pull off the rubber part of the roller and rotate it 180 degrees from it former position which gives it a new area of wear. Usually that's a pretty good fix, and it isn't too hard to do, just make sure to note how it was put together before taking it apart. Good luck.
Aug 29, 2007 | Brother HL 1440 Laser Printer
Paper sent through without printing
You should try cleaning the pick up roller. It may be your paper has quite a dusty surface and this will cling to the pick up roller making it less grippy. When the paper is fed it may not make the first sensor in the expected time and thus creates the error. Get a service manual to show you how to get a t the pick up roiller so you can remove and clean it. You can get Platen Cleaner from many web sites and it is specifically formulated to regain friction os such rollers. Try either: http://wwwTheServiceManualShop.com or http://mikeburton.tradebit.com/ for a service manual
Apr 11, 2007 | Epson Stylus Photo R2400 InkJet Printer
Samsung CLP 300 Laser Printer Logo
185 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
